Fox 32 float 140m
[Closed] Fox 32 float 140m
Hi all I've just upgraded my forks to fox floats there 15m bolt throw and was just wanting to know what the nut on the other leg is for it has numbers on it 1 to 18 it's what the axle bolts into it has a marker on it and is set at number 15 at the moment??
Posted : 27/03/2012 9:43 pm
Tightness / position of axle qr lever when it is tight.
Posted : 27/03/2012 9:49 pm
Use it to set the position that the quick release lever sits when closed at the correct tension.
Posted : 27/03/2012 9:51 pm
