Forking Forks - Hel...
[Closed] Forking Forks - Help!!
Im trying to remove the lowers from some Sektor coils but will they come off ๐Ÿ˜ˆ
I have tapped the rebound bolt and that has freed from its position but the other side wont knock in.
Is there actually anything on that side to knock up into the fork?
Posted : 26/09/2014 6:49 pm
Yeah the spring rod. Just sounds like you might need to hit it harder, takes a fair whack usually. Undoing the top cap might help
Posted : 26/09/2014 7:24 pm
So there definitely is one on the coil fork?
Posted : 26/09/2014 7:26 pm
