Fork Stiffness-Give...
[Closed] Fork Stiffness-Give me a reality check!
Hi
Currently got 150 Revelations (1 1/8 steerer) on my bike but it will also take tapered or 1.5 inch steerer.
Will I actually notice a difference in "stiffness" or even performance (however you want to describe it)if I fit a tapered steerer Fox 32?
As a seperate question will I also notice a BIG ie worthwhile difference in performance/stiffness etc etc if I swap to a Fox 36 or Lyric?
Any thoughts appreciated
Steve
Posted : 30/07/2012 1:10 pm
My Rize came with OE Rev Race QR 1 1/8" steerer and they were as stiff as an overcooked noodle. The suspension action was superb but imo the chassis is a 100mm fork stretched to the max and beyond in 150mm guise. They are light for a reason
I swapped them for tapered steerer 20mm axle Rev Teams and they were better but could still see the legs twanging/walking in corners and they bow outwards on sudden impacts.
Have ridden Fox 36s and Lyrics they are fundamentally much stiffer but there's a weight penalty.
What we really need is some 34mm dual-crown Revs
Posted : 30/07/2012 1:17 pm
No direct expirience to make the exact comparison you describe, but I would imagine...
Q1 - No (unless its worse),
Q2 - yes very probably.
32mm 150 forks are silly imo.
Posted : 30/07/2012 1:23 pm
depends...
is there a difference - yes
will [b]you [/b]notice a difference - maybe, depends how you ride
will you [b]notice [/b]a difference - again, maybe, see above
is it a [b]worthwhile [/b]differnce - depends on your interpretation of worth... what is a X% noticeable increase in stiffness worth to you in £?
32mm forks with 140mm + of travel can be a bit noodly, doubly so if using 9mm QR, personally I think a bolt through axle is worth a lot more than a tapered steerer as an upgrade but it always comes down to weight and cost and whether or not it matters enough to you and your riding.
sorry that wasn't very helpful
Hi
Thanks for your thoughts so far.
Should say my Revelations have 20mm Maxle
Steve
Posted : 30/07/2012 1:28 pm
If your Revs are already 20mm axle a tapered steerer will make a noticeable difference but not enough imo to justify the price of some new forks. They are still Revs.
imo the problem lies with the skinny stanchions and lightweight lowers they are simply not gnar enough. No telescopic fork works when it leans over but the two Revs I've had both flexed sideways as well.
Lyrics don't flex but they're heavier.
Posted : 30/07/2012 1:36 pm
In that case I wouldn't bother with the tapered steerer option, either stick with what you have or go for a bigger chassis.
What you haven't said is if you're actually having problems with fork flex?
Posted : 30/07/2012 1:44 pm
I can see a tapered steerer making a huge difference if you already have a 20mm Maxle.
Fox 36 or Lyrics (which are 35mm) are obviously a lot stiffer.
I run Revs and find them stiff enough but mine are the first 150mm ones that used the Pike lowers they are about 300 grams heavier than the new Revs, I guess you can't run lightweight lowers and expect them to be really stiff
Posted : 30/07/2012 1:52 pm
