Noticed whilst fiddling with my bike that my Rockshox Recon 351 Solo Air 120mm forks had a bit of oil on the stanchions, now the forks have only been ridden 5-6 times and were brand new when i put them on, is this normal part of them bedding in or something wrong. The amount of oil is not huge just a smear on each stanchion enough to make the dust leave little rings of travel marks.
Normal fella, assuming it's only a smear nowt to worry about 😉
just keep an eye on them if your worried, but you'll be worrying about nothing imho
mine do that on my fox float rl`s but Ive had mine for about 2 years now, they started showing oil just recently, but ive also got wear on my stanchions which i need to get sorted so ill prob just sort the whole lot when i book it in for a service
It's healthy, shows the the foam rings are nicely lubricated under the seals. I've just serviced my Rebas and it specifically says to lubricate the foam rings.
Cheers guys good info.
