fork length and whe...
[Closed] fork length and wheel size musings
I've a pair of 26" Fox 36 forks. One day, 26" will be no more. If my forks are still alive by then, I'm wondering if I can convert them to 650b by sacrificing some travel.
The travel is reduced by putting spacers in to limit extension. If these spacers were fitted in a different location, they could limit compression. So, assuming a 650b clears the arch, is it possible to turn a 26" 160mm fork into a 140mm 650b fork?
What is the crown to axle length difference between 26" and 650b forks of similar travel?
Posted : 04/10/2014 8:17 pm
One day, 26" will be no more. If my forks are still alive by then...
They won't be - unless you bought then as a wall ornament rather than suspension component.
(10-12mm A-C difference for equal travel).
Posted : 04/10/2014 9:09 pm
They're well looked after and showing no signs of their age yet, although having Avalanche internals has certainly helped with that.
Posted : 04/10/2014 9:24 pm
Just put some 650b in my 34's, clearance is the biggest issue as I'm not going to get anything more than a 2.25 Ardent in there (my default choice for 9 months in Sunny Oz) If I want to go to the HRII's etc I can just throw the 26" back in there.
Posted : 05/10/2014 2:28 am
