Fork Length and hea...
[Closed] Fork Length and head angle
Anyone out in the stw wilderness know how much you change your head angle when fitting longer forks or winding talas up and down etc?
eg. 15mm=1 degree????
Posted : 14/02/2012 11:32 am
It's more like 1 inch/25mm to 1 degree
Posted : 14/02/2012 11:40 am
17mm sagged from a calculation I did once.
I think it's pretty transferable to all mtbs, though someone did call me on it, turned out to be yet another "you're wrong because I say you are even though I offer no explanation" type.
Posted : 14/02/2012 11:44 am
Sounds like Al has worked this out whereas I've just quoted from 'urban myth' ๐Ÿ˜€
Unless someone has a better answer, I would go with Al
Posted : 14/02/2012 12:16 pm
[url= http://gearinches.com/blog/misc/bike-geometry-comparator ]knock yourself out[/url]
Posted : 14/02/2012 12:22 pm
I should add "give or take a mm or 2" in case the pedants arrive...
Posted : 14/02/2012 12:27 pm
It's 20mm per degree for normal range of fork lengths / head angles.
Posted : 14/02/2012 12:39 pm
cheers folks ๐Ÿ˜€
Posted : 14/02/2012 12:46 pm
al is wrong, totally and completely wrong, so wrong in fact, i cba to correct it.
Posted : 14/02/2012 12:47 pm
Oh no, now jameso's said that, I might have to calculate it again...
Posted : 14/02/2012 12:52 pm
Nah ) 17mm, 20mm, it's close enough for fork-length faffing. If I lay out a bike geometry and change the fork length alone, that's what I get.
Posted : 14/02/2012 1:05 pm
sagged or unsagged?
Posted : 14/02/2012 1:06 pm
sagged or unsagged?
TJ has a point. 20mm of sagged fork height will give more of a change in head angle than 20mm of non-sagged fork height.
Posted : 14/02/2012 3:59 pm
