Fork crown race--sp...
[Closed] Fork crown race--split ring
[#2395113]
Currently have a Ritchey Comp hset, the fork crown race is of the solid type, ie it is not a split ring; makes changing forks etc a real pain :( as Im used to the FSA / Hope units previously with split rings. Could I either cut a slot in the race making it a split ring or 2. Get hold of a split ring compatible with the Ritchey h`set?
ta
Posted : 23/01/2011 5:52 pm
Yeah, cut a slot in it - just make sure you file off any sharp bits.
Posted : 23/01/2011 6:04 pm
hit it with the junior hack saw. i have done two are three like that, no problems at all.
Posted : 23/01/2011 6:06 pm
Thanks :), hacksaw at the ready---cant think of any engineering reason too why this is not perfectly satisfactory as the split ring will becontained` with the bearing race itself
Posted : 23/01/2011 6:08 pm
I almost resorted to this when fitting a fork recently, but got the crown ring on by heating it with a ciggy lighter, dropping on the steerer, then tapping it down using an old stem (the end the holds the bars) and mallet. It probably wont come off now.
Anyway, when I was heating the ring these words of fire appeared, in cryptic fine script, and glowed. What's that all about?
Posted : 23/01/2011 6:19 pm
