hello there im after some well required help on fork choice & advice.
i have the option from my lbs to purchase either of the following 2 forks.
rockshox revelation dual air team 20mm bolt thru 150mm travel or
fox float r 32 140mm qr.
they where both taken off bikes that have never been used & he is wanting the same for both prs.
is there a clear winner out of the 2.the revs are bright white where the fox are grey but beyong that my knowledge is flawed.
he has said i can have a set of 20mm adaptors for my hope wheels free if needed.
aslo would 10mm make a hugh difference .
they are going onto a ornage crush btw.im a lightweight at 9st .
thanks guys
The Rev is a great fork and the 20mm axle is a great upgrade, making it the clear winner IMO.
cheers chakaping ill give it some thought
Yep, as per what chakaping said, I'd buy the Revs
