flexible plastic, l...
[Closed] flexible plastic, like what mudguards are made from?
 ton
[#7962410]
anyone know where you can buy flexible plastic?
Posted : 25/07/2016 10:26 am
Mucoff bottles are made of it, cut one of those up
Posted : 25/07/2016 10:28 am
polypropylene sheet I think.
Posted : 25/07/2016 10:29 am
 JAG
Lots of household stuff is made of this stuff. How much and what shape?
Posted : 25/07/2016 10:31 am
 ton
I want 2 long strips to make so guards for 3'' + tyres
Posted : 25/07/2016 10:33 am
[quote=ton ]I want 2 long strips to make so guards for 3'' + tyres
TJ used traffic cones...
Posted : 25/07/2016 10:34 am
 ton
seen a good bodge on a yank fatbike forum. pair of sks longboards, cut down the middle lengthways, then a 3'' strip riveted in the middle.
Posted : 25/07/2016 10:39 am
I've seen fatbike mudguards cut from a water butt. Just find one the right diameter.
Epicyclo just uses trials bike guards for his fatbikes. You could cut those down a bit. They are pre-shaped and relatively cheap.
Posted : 25/07/2016 10:45 am
If you don't mind them being orange, I cut up the top and bottom of a couple of Jacob's cream cracker plastic boxes to make four enduro style front mudgaurds for all of our bikes.
Posted : 25/07/2016 11:37 am
eBay sells sheets of plasticard cheap.
Posted : 25/07/2016 12:05 pm
Decathlon Mudguards fit over Chronicles Tony.
Posted : 25/07/2016 12:18 pm
Plastic folder cover
Posted : 25/07/2016 12:23 pm
 ton
I want full length guards.
Posted : 25/07/2016 12:28 pm
An A3 plastic folder cover...
Posted : 25/07/2016 12:36 pm
 ton
full mudguards for a 29+ will need to be 1.2 meters long
Posted : 25/07/2016 12:41 pm
[url= https://www.kickstarter.com/learn ]KICKFART [/url]it
Tron colours pls
Posted : 25/07/2016 12:55 pm
[url= http://www.ebay.co.uk/itm/A4-Coloured-Polypropylene-Plastic-Sheet-0-8mm-Binding-Art-Craft-Model-Making-/162110950517?var=&hash=item25be90cc75:m:mrHDeH9e5vpDE-doQB9e5Aw ]Polyproylene sheet on Ebay A4[/url]
Other sizes are available as are transparent colours.
Posted : 25/07/2016 1:00 pm
I use trials bike rear mudguards on my fat bike. For a plus tyre the [url= http://www.tytrials.co.uk/trailandtrialsuk/prod_137190-Universal-Trials-Fender-Mudguard-Front.html ]trials bike front mudguard[/url] would probably be the trick.
The good thing about them is that they are not flimsy and don't flap around, but you will have to make your own stays (not difficult).
It makes a hell of a difference - big tyres can chuck up impressive amount of filth.
alexxx - Member
Useless. I tried that as an extender on my mudguards and it lasted half a lap of the 'Puffer before it fatigued and cracked.
Posted : 25/07/2016 1:28 pm
 ton
epicycle.....perfect
any tips?
normal metal stays araldited on?
Posted : 25/07/2016 1:40 pm
No one mentioned traffic cones yet?
Posted : 25/07/2016 1:50 pm
I have a tip - Araldite doesn't work on polypropylene so save yourself 4.99 trying
Posted : 25/07/2016 2:22 pm
[quote=Houns ]No one mentioned traffic cones yet?
Keep up at the back!
[quote=jam bo ]
Posted : 25/07/2016 2:35 pm
3ltr coke bottles sellotaped together? Sort of like this?
Also random image that comes up when you google coke bottle images 😆
Posted : 25/07/2016 2:41 pm
Posted : 25/07/2016 2:56 pm
ton - Member
...normal metal stays araldited on?
I just use alloy tubing from B&Q. Flatten the ends, curve to shape the bit that goes on the mudguard, then drill holes to suit.
Click through from here and you'll see how I did it on one bike.
[url= https://c2.staticflickr.com/8/7495/15655585913_3521f278ea_b.jp g" target="_blank">https://c2.staticflickr.com/8/7495/15655585913_3521f278ea_b.jp g"/> [/img][/url]
I also have used flat strap, but that's not as good IMO.
Posted : 25/07/2016 3:06 pm
How about cutting up a pair of 'Festival wellies"? Then you could have anything from a Union Jack to Daffy Duck...?
Posted : 25/07/2016 4:03 pm
