''Fixing'' bleed po...
''Fixing'' bleed port on lever - 7.9mm hole to fit 8mm tube?
Going to attempt a fix on a stripped bled port rather than replace lever with a insert made out of m8 aluminium tube.
Will need to drill out the plastic lever a bit to allow the 8mm tube - will a 7.9mm drill bit be suitable or will it still be too tight? Bearing in mind I'll be using a hand help drill so probably will be a bit of wiggle!
Will be epoxying it too.
Any thoughts appreciated.
ย
Posted : 14/05/2025 10:40 am
Sounds reasonable to me, an interference fit is generally for something you want to stay fixed and not move about. 0.1mm might be a bit tight for such a small diameter but as it's going into plastic you'll have a little give. Obviously don't force it in if a firm press doesn't work. Nothing to loose really as you have a fall back position of drilling it out to 8mm or even just replacing the lever.ย
Posted : 14/05/2025 12:32 pm
