toothpaste tube? do i need to attach it to the tyre in any way?
love my maxxis advantages, but they got a hole in them. just can't stand the NN replacement, so want to fix it (cos i'm skint).
whats the best way?
I've mended a small slash using a bit of old tyre stuck to the inside; no problems with it since.
As above, superglue cut and then stick old tyre sidewall to inside of tyre over cut, did this on a 1" cut and tyre was used untill no tread left
Tracey
I've used a few layers of gaffer in the past, more than a few times. Worked fine.
I sew the slash up with dental floss. WOrks fine.
rightio... will have a think. need some superglue it seems (however, does it dry quick?! need to do it tonight for use tomorrow)...
Did mine in a few mins
Tracey
Don't think super glue'll do the job not flexible, use the stuff useed for tubes patches.
Superglue dries fast. I'd also consider sewing the patch on with fishing line, if it's big enough.
Superglue for the cut, puncture repair glew for the patch
Tracey
Not a permanent fix, but for get you home emergencies I always carry a 6" square of damp proof course to wrap round the tube under the hole.
