Fitting a Hope X2 r...
[Closed] Fitting a Hope X2 rear brake - advice please
As a complete spanner numpty I thought I would have a go at fitting a Hope X2 brake to my Salsa Fatbike.
The routing is internal, and I have ordered the Hope bleed kit.
So, can I remove all the Dot5, undo the banjo and thread it through the frame and bleed the system or is there an easier way.??
Any tips or advice really welcome. 😁
Posted : 09/07/2018 6:02 pm
Remove banjo and inner barb, screw a tiny screw (laptop/glasses etc) into the hose and thread it through the frame.
When through trim the hose to length and refit banjo fittings.
Bleeding should just be a case of of using some tubing on the bleed screw if it's like my E4's with tech 3 levers.
Posted : 09/07/2018 6:05 pm
