Did anyone else find it a hard tight fit fitting a ccdb to the shock mounting on the swing arm or is it just me?
Posted : 18/10/2013 2:37 pm
It was hard fitting one on my five if that helps. The powdercoat was quite thick, maybe worth filing some of it off
Posted : 18/10/2013 2:46 pm
Cheers flange,managed to get it in just getting it lined up for the shock bolt is the hard bit.
Posted : 18/10/2013 2:55 pm
Probably sorted this now - but if not, use the shaft of a screwdriver pushed through the eyelets to line the shock up with the mounts
Posted : 21/10/2013 10:06 am
