So as part of my training plan today was marked in for fitness testing, or sweating like a pig on cycle machine whilst someone stuck needles in me.
I decided that I'd like to know my baseline fitness levels partly to confirm which heart rate zones I should be training in, and partly so I can conduct the test again in a few months and know for sure if my training plan is working.
And the cunning bit is that I can claim the cost of the test back against my yearly "sports" allowance from my company.
Anyway I cycled away happily at 80 watts and every 180 seconds the machine increased the load by 40 watts, and after 23 odd minutes I died a death and gave up.
Amongst the many things I found out was the following, my aerobic threshold is 162bpm at 250 watts or more interestingly 3.35 watts/kg of body weight. Somewhat off from the 5.8 to 6.2 range of Tour riders. With a peak at 350 watts and a max pulse of 179.
I now need to adjust my training zones as before I was using 174 as my max pulse.
Train hard and according to plan and wait 3 months and test again.
To be continued....
a max pulse of 179.I now need to adjust my training zones as before I was using 174 as my max pulse.
Sarcasm?
Actually in all seriousness although I can see how easy it would be to think the opposite ๐ฏ
Very similar to mine i had done in december
I came out at 3.32 watts per kg. Was 75kg then.. now 73
So did they say what your base fitness was like?
EDIT: Oops.. Sorry it was 3.2watts per kg
My 3.2 watts/kg figure is based on functional threshold which is less than actual threshold
179 vs 174, how much does that shift your training zones by exactly?
Quite a bit as it turns out ๐ฎ
Max 174 179
95% 165 170
91% 158 163
84% 146 150
82% 143 147
75% 131 134
72% 125 129
65% 113 116
Where did you get it done and how much was it?
I live in Sweden so maybe not that much use to you, but quite a few places in the UK provide the same service. I paid just under a hundred quid for that test, and some other blood tests. Overall it took 90 minutes including consultation time.
Well worth it in my books.
hmmm maybe i can ask the sports science bods if they want a guinea pig then see how 3 months of tri (not) training affects my figures
What came out of mine is I need my percentage of energy from fat at aerobic base point to be bigger and to increase my functional threshold power to over 4 watts per kg
