First FS build up- ...
[Closed] First FS build up- what length rear mech? Help meeeeee....
I'm busy putting a Commencal Supreme 6 together and have no idea what rear mech to use. I've got a short and long cage X9 to choose from. I was thinking that perhaps the long cage would be best, seeing as how I'm using an 11-34 cassette and the chain will have to be long enough to allow for the travel but the mech will also have to be able to take up the slack of the range of gears throughout the travel.
Also, do I need to remove the shock to drop the bike low enough to fit the chain? I think the answer is 'yes' to this one.
Noob questions...
Posted : 19/06/2015 10:10 am
How many chaninrings are you running? You'll probably get away with a short cage if it's 1x with an 11-34 but it's always better to have too long a mech cage than too short.
To fit it? No, just join the chain with it sitting around the BB shell if you find it hard to hold against the mech tension then lift it onto the ring once it's joined. If you mean to check the length, then still no, just let all the air out of the shock.
Posted : 19/06/2015 10:20 am
It's 1x9 with 11-34 on the back and it's a coil shock ๐Ÿ˜•
I'll use the short on my HT and put the long on the FS- thanks for your reply!
Posted : 19/06/2015 10:23 am
a coil shock
Then yes, your easiest way to check the chain is long enough is to take at least one end of the shock out.
Posted : 19/06/2015 10:37 am
robinlaidlaw - Member
I'd take th espring off and refit the shock, some linkage bikes go all weird when there's no axle - although the commencal is fairly normal
Posted : 19/06/2015 10:42 am
Brill, ta.
Posted : 19/06/2015 11:01 am
Im confused, why would you need to touch any of the suspension to fit the chain?
Surely you just split and join the chain once its routed correctly?
Posted : 19/06/2015 11:06 am
On a FS you need to measure the chain under compression otherwise the chain will be too tight due chain growth when activating the travel, some suspension designs minimise this however.
Posted : 19/06/2015 11:55 am
Or just leave a reasonable amount of slack in the chain. It's not rocket science!
Posted : 19/06/2015 11:58 am
I'll be using the bike for [s]racing[/s] having a go at DH, I don't want any slack in the chain at all except for when I need it, ie at the extreme of rear travel, and this being the first time I've built a FS up I thought I'd ask for advice. Why the cocking f- I need to explain that is beyond me though.
Posted : 19/06/2015 1:11 pm
Keep your hair on princess. I asked a simple question about why you were doing what you were doing. No need to get so pissy.
Posted : 19/06/2015 3:28 pm
biggest ring, to biggest ring, plus 2 links - i wouldn't worry about chain growth, never caused me problems
Posted : 19/06/2015 3:46 pm
this it's what i've always done on all my mike covered a broad range of suspension designs and never had an issue
Posted : 19/06/2015 4:34 pm
