Happy days!
LBS fitted the headset for me but the rest all my own work (and it shows...)
Everything a straight swap from the PA so I had a fair comparison.
Had a shorter stem on the PA, and neither that nor the current stem are quite right yet but getting there.
First ride tonight was interesting- the Ti456 rides very differently to the PA.
Now, what to do with a battleship grey 853 PA frame... ๐
killer bee tyres? what are those?
Looks fine apart from front brake hose needs ziptied to the fork arch
Is linking to CRC allowed?
Apologies if not, but tyres are here:
http://www.chainreactioncycles.com/Models.aspx?ModelID=29149
Really fast on road and hardpack, at least
do they make a buzzing noise on tarmac, panaracer fire xcs used to
I'm on zip tie duty tomorrow, wanted to get a ride in before I lost the light!
No buzzing- I've run fire xcs in the past but wasn't a fan. There's almost no tread on the Killer Bees so they're effectively silent, only thing that warns people that I'm coming is my wheezing ๐
How do you mean "different"?
PA was a large, 456 is a medium.
Not looked at the numbers but the geometry seems different- possibly as a result of the different frame sizes- the seatpost seems like it's at more of an angle on the 456, and it seems to work the fork more. Not that I'm passing opinion, it's just different.
I could be talking a load of guff but so far (after one ride!) I'd say that the PA felt 'springier'.
Currently the 456 feels too stretched out (but I can probably solve that by changing the stem) and the PA seemed easier to pedal on the flat, somehow.
456 seems to climb better though and is certainly the lighter frame.
Nice 456 - Are you thinking of parting company with the PA? - if so I'd take it off your hands.
why are you posting at twenty to four in the morning?
I'm currently on holiday in New York - whay may I ask are you? ๐
callout. Loads of yanks on the line scratching their heads not able to understand netmasks.
You're in the same country as them, give 'em a kick! ๐
uuuuuuuuuummmm, not actually sure what these netmasks you speak of are, though I will kick the nearest salad-dodger I see.
cheers, I'm sure it'll do the job
aaah, there we go, they've got it now. Thanks
