First build project...
[Closed] First build project...
...will soon be underway. The piggy is hopefully being dispatched today and then the build can start (under the very close supervision of Skiboy ๐Ÿ™‚ )
I've never done this before so really looking forward to it all coming together.
Any stories of first build mishaps/lessons learnt?
Posted : 18/12/2009 11:06 am
Nope should be fine. Just take care with BB and pedal threads, use plenty of grease too. Also be careful when cutting cables to length and look carefully where to fit the heli tape our rubbed paint will make you swear after your first ride. Make sure you assemble the headset correctly - it's easy to mix up the races and things
Posted : 18/12/2009 11:18 am
Measure twice, three times even, & cut once.
Posted : 18/12/2009 11:26 am
Is it just me or have got a little carried away and posted the thread a bit early, it means nothing wihtout being finished and pictured!
Hurry up.
Posted : 18/12/2009 11:30 am
Totally carried away for sure ๐Ÿ˜ณ
Posted : 18/12/2009 11:40 am
Take pics all the way throuh the build tehn you can post up a flick book ๐Ÿ™‚
Posted : 18/12/2009 11:41 am
excused... post em when you got em.. ๐Ÿ™‚
Posted : 18/12/2009 11:44 am
tinsy i bet it gets done before my first build.
one tip i can give is if you are using a headset off an old bike make sure you keep the crown race that is fitted to the forks on that old bike.
I kept the old headset but threw the old forks away (which still had the crown race attached)and am now either trying to find a crown race to fit or go for a whole new head set + crown race :o(
Good idea on the pics. Frame should be here Monday, hurry up indeed!!
New headset coming with the frame
Posted : 18/12/2009 11:46 am
misshaps/lessons learned,
Don't give skiboy vodka prior to starting,
Don't give skiboy Vodka during build,
Don't let your boys cut the steerer tube,
Don't let my girls near the thing fullstop,
Don't let our wives get involved,
๐Ÿ˜‰
Posted : 18/12/2009 11:58 am
[*]remember the wheels go at the bottom otherwise you will have to lay on your back to ride it once its finished
good luck!
Posted : 18/12/2009 12:05 pm
I'll keep the vodka for once the tools have been put away (phnar, phnar). No children or wifelets to be allowed within 30' ๐Ÿ˜†
Posted : 18/12/2009 12:22 pm
Don't try to finish too late in the evening. You get tired and mistakes happen.
I was taking brakes from one 456 to another, had to cut the hose as it runs through closed guides. I then replaced the hose with the new un I had for the purpose, forgetting to run it through the new frame! D'oh!!!
Should have been in the pub by that point and finsihed the next day ๐Ÿ™
A
Posted : 18/12/2009 12:40 pm
Posted : 29/12/2009 12:57 pm
And here it is ๐Ÿ˜†
I see Skiboy posted earlier on another thread on this so some more piccies here. Was a joy to work on and turned out just as I hoped it would. I think for a first bike this is going to be awesome. Big big thanks again to Skiboy for his help. I guess I owe you that Vodka now ๐Ÿ˜ฏ
Posted : 29/12/2009 1:27 pm
