Feeding a reverb ca...
[Closed] Feeding a reverb cable- is the fluid nasty?
3 Users
Hi all,
Another question (this build will be done in a few weeks and I'll stop asking questions every 5 mins).
When you feed a reverb cable through a frame, do you get hydraulic fluid inside your frame?
I thought it was pretty nasty stuff, eats car paint etc?
If so can it damage carbon? Am I best to completely drain the cable?
Posted : 23/01/2019 11:52 am
Reverbs don't use DOT fluid, it's mineral oil.
Posted : 23/01/2019 11:54 am
Either buy one of these:
https://www.tweekscycles.com/uk/rockshox-reverb-stealth-barb-connector-srmtls815066030
or just bung something in the end to block the hose.
using the joiner with a length of empty hose fed through first to draw the full hose through is a much easier job and you can (if you're lucky) avoid a bleed.
Posted : 23/01/2019 11:55 am
