FAST damper upgrade...
[Closed] FAST damper upgrade on pike rct3
Sending my pike into tf for a well deserved pampering, and noticed they offer a FAST upgrade to the standard charger damper for £160 including the service.
Has anyone had this done, and what's the verdict?
Posted : 26/02/2015 4:11 pm
Mine are booked in for tomorrow, they won't be back until Monday so I will try and report back next week.
Posted : 26/02/2015 4:35 pm
There are actually 2 different tuning variations they do.
One is just the rebound piston, which I think is designed to stop the spikey rebound effect you can get with them, the other is basically replacing all the internals of the Charger Damper, it changes them to a separate HSC & LSC adjuster
The latter is designed to give you a bit more of a usable range of LSC & replace the RS equivalent of CTD with an actual HSC adjuster. I think they replace everything in the Charger damper for that part.
Posted : 26/02/2015 5:55 pm
It sounds a little bit like they've invented the Lyrik 😆
Posted : 26/02/2015 5:57 pm
Possibly, but without the extra boat anchor attached to it 🙂
There may even be rumours of a spring conversion kit too...
Posted : 26/02/2015 5:59 pm
They already offer a spring conversion for it.
Posted : 26/02/2015 7:31 pm
Keen to find out the knitty gritty on this.
Posted : 26/02/2015 8:53 pm
Lyrik was open bath, heavy and divey in comparison to the pike. I believe it has proper midvalving as well.
Anyway, avalanche do a similar conversion. They go a little bit further than FAST I believe, including bringing the bladder system inline with what you see on motorbike forks.
http://www.avalanchedownhillracing.com/Rock%20Shox/Pike%20Charge%20Piston_Valve%20Upgrade%20Kit.htm
Link? There's a company in Germany doing ti springs for the mattoc.
Posted : 26/02/2015 8:54 pm
So what you're saying is ive got a pike after two years of reviews and Internet forums saying its a great fork but now without this upgrade is basically pants....stw .n+1 strikes again 🙂
Posted : 26/02/2015 9:16 pm
Well, I'm new-ish to Pikes, about 6 months, and although they're stiffer than my Revs, I found the damping quality a bit of a disappointment after all the hype. They're nice enough, but not that much different from what I had before.
Posted : 26/02/2015 9:49 pm
Call TF Tuned.
http://www.tftuned.com/tech-help/22-rockshox
Posted : 12/03/2015 1:06 am
Call TF Tuned.
/p>
That's for the Lyrik.
Didn't notice that notchiness that you got on the Lyrik solo airs in the Pikes either, they were smoother than my newly serviced coil Lyriks!
Posted : 12/03/2015 1:14 am
