Fanbelt type materi...
[Closed] Fanbelt type material...?
6 Users
I need to repair the flexible towing hitch on out child trailer. The 'flex' is enabled by a piece of hose inside a spring. The spring is 14mm ID. I have snapped the hose twice, so I need to beef-up this connection with something that is less likely to tear where the bolts go through.
I was thinking of the reinforced rubber stuff that fanbelts are made of. Any idea where I'd source 14mm diameter circular section stuff? (or similar)...
Posted : 17/10/2013 8:01 pm
If its a Burley I used to repair them with the hose from fire extinguishers.
Never used to break after that and the hose is cheap too.
Posted : 17/10/2013 8:15 pm
Where did you get hold of hose?
Posted : 17/10/2013 8:57 pm
I could hazard a guess
Posted : 17/10/2013 9:16 pm
See if there are any fluid power suppliers in your area - Google "hydraulic" or "pneumatic" and if they have a trade counter, go and see if you can blag an offcut of hose.
Posted : 18/10/2013 7:58 am
My local scrapyard has all the old fire extinguishers from Chubb sat waiting to be bought, We have loads knocking around which we buy for a fiver a time and use them for water fights in the summer 😉
Make sure you buy them with schraeder valves so you can refill them regularly 😉
Posted : 18/10/2013 7:10 pm
http://www.pirtek.co.uk/
Posted : 18/10/2013 7:27 pm
PePPeR.. would you mind getting in touch about your post re - central heating ?
on here
http://singletrackworld.com/forum/topic/_does-anyone-know-about-heating-cottages-hot-water-rayburns-agas-and-stuff
would really like a chat, just seen your post, but you don;t have many details in profile,.
(sorry this isn't to do with post)
Posted : 25/10/2013 11:01 pm
