(not me I hasten to add)
track pump head won't fit in recess on aero wheels. Is there an adapter tube you can get to fit on the valve one end and onto your track pump the other?
thanks
Could be wrong here but don't aero wheels need specific tubes with longer valves to get through the depth of the rim?
Or am I thinking of something else?
I think charlie's talking about a disc wheel, where there's a small cutout in the disc to let you fit a pump (or not, as the case may be).
Silica do a crack pipe adapter: http://www.sjscycles.co.uk/silca-disc-wheel-adapter-prod23401/
You might need to google round for someone who has it in stock or maybe resort to ebay. I can't offer an opinion on how good it is, I'm using a 404/808 combo so don't have disc worries ๐
EDIT: also found ones by [url= http://www.wiggle.co.uk/fast-forward-disc-wheel-valve-adaptor/?lang=en&curr=GBP&dest=1&utm_source=google&utm_medium=cpc&utm_campaign=Dynamic+Search+Ads+Cycle&referid=googwig&gclid=CISltMvfg7cCFVMbtAodkCcAAQ ]Fast Forward[/url] and [url= http://www.evanscycles.com/products/zipp/disc-valve-adaptor-with-5-z-patches-ec045550?utm_source=froogle&utm_medium=froogle&utm_campaign=froogle&utm_content=mkwid__pcrid_17321847296_kword__match__plid_ ]Zipp[/url]
Silca crack pipe or hirame adaptor.
Ah I see.
thanks - not actually a full disc wheel but HED tri spokes, so same idea
will get googling about those adapters
crack pipe adaptors are ime a pita, never got a good seal with them, the Hirame is a very good bit of kit but expensive. Having got one i lopped the normal adapter of my rennkompressor and just fitted the hirame, so no faffing around. you can get copies which are cheaper and probably just as good
Just get a valve extender. Most good road shops will sell them.
That would just extend the valve past the cut-out... It's not a plain deep section wheel he's on about, he needs a 90 degree adaptor as others have suggested
