explain the differe...
[Closed] explain the difference please
i have an '09 spesh epic and it needs new chain rings bb bearing. i've been looking at replacement/upgrades and am a bit stumped by the choices from shimano. please explain the difference and which one i need. ta
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=23102 ]XT M771[/url]
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=20679 ]XT M770[/url]
Posted : 12/02/2010 10:32 am
771 - 48/36/26 tooth
770 - 44/32/22 tooth
And they look a bit different
Posted : 12/02/2010 10:34 am
M770 = standard for most bikes- ie. 22-32-44 chainrings
M771 = designed for touring- 26-36-48 chainrings. Theres a spacer on the axle so it sits ever so further out to aid chainstay clearance.
M771 is good if you plan on running a double+ bash setup, 26/36 is better for that I reckon.
Sounds like you need M770..
Posted : 12/02/2010 10:36 am
as above plus crank lengths vary, 175mm is "normal", 170mm of your shortish, 180mm if your huge
PS the 48/36/22 is "touring" gearing
