Erm, any tips on re...
[Closed] Erm, any tips on removing blue threadlock from internal threads?
From the inside of the disc bolt holes on a hope hub?
Putting a different set of wheels onto a bike and went to put a disc on the rear hub and there's some old blue threadlock in there making it very hard to do the bolts up. Can't get any type of brush I have to hand in there. Any ideas on getting this stuff out? I don't have a tap or anything else to run through it either. Anyone had any luck disolving it with stuff you'd find around a normal house? ๐Ÿ˜•
Posted : 26/06/2016 10:17 am
Boiling water might work. Most threadlock releases about this temp. You might be able to swab it out.
Posted : 26/06/2016 10:19 am
I'll try that. Internet says heat or some chemical and I don't really want to put a blowtorch on the hub and don't think I'll be able to get the chemical stuff today.
Posted : 26/06/2016 10:39 am
Leave it in for the new bolts.
Posted : 26/06/2016 10:44 am
falkirk-mark - Member
Run a tap through it, should get most of it out.
Hot or Cold?
Posted : 26/06/2016 10:45 am
Thread tap is the right way
Ah ha!
Found some q-tip things, boiling water and ...
job done!
I'll use some fresh stuff on the threads, these wheels had been in the loft a couple of years.
๐Ÿ™‚
Posted : 26/06/2016 10:53 am
