enduro bearings in ...
[Closed] enduro bearings in hope bottom bracket ,will it fit, are they worth it ?
 dale
2 winters 18 months and 2500 miles of riding in the grit triangle with 3 re-greasing' has caught up with my bb (bearings spin but too much play).So do they fit ?,is it worth the saving over hope ie. £ per mile ? How are youre enduro's holding up ?
Posted : 19/03/2010 8:35 pm
Yes, go for it. Mine are 100% smooth after a year. Can't tell about VFM in such a short time though.
FS owners might like to consider Enduros for their pivot bearings. I found the originals from my Ibis Mojo totally shot after 12 months. The new set of ceramics are running sweet.
Posted : 19/03/2010 9:12 pm
Posted : 19/03/2010 9:13 pm
 dale
is that yes they do fit the hope cups ?
Posted : 19/03/2010 9:39 pm
 gamo
I thought the Hope bb,s used different sized bearings to
Race Face and Shimano ones?
Posted : 19/03/2010 9:47 pm
 dale
I was hoping it was the internal dimentions that were different
Posted : 19/03/2010 9:58 pm
I forget the type number, but if you're not sure then [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=36418 ]THESE[/url] are probably just as good.
Hope use stock bearings in their hubs . I've put Enduros in those as well.
I got mine from Superfly USA. No customs charges so far.
Posted : 19/03/2010 10:18 pm
Hope dont use a stock bearing, the bearings in the hope bb fit directly to HT11 axles - most other bb's inc shimano etc use a plastic top-hat to take up the 1mm of remaining space. (26 instead of 25mm if i remember correctly, its 1:45 am and im tired...)
Enduro bearings will fit but you will need to use a non-hope seal, im assuming you used the enduro one?
'Standard' 68052rs wont work without a tophat in the hope BB - Hope use proprietory bearings from a uk bearing company that i forget the name of, you cannot easily purchase the hope bb bearings without going through hope (if at all)
The hope bearings are very high quality anyway.......
Posted : 20/03/2010 2:40 am
crankrider is right hope bb beaings are not the standard ones as fitted to shimano etc
Posted : 20/03/2010 9:47 am
I might be wrong but I thoughtt he bore on the shimano bearings was 25mm so they fit a 24mm axle with a tophat cap. The Hope and the Enduro fit directly to the axle and both have a 24mm bore. Assuming the outer diameter is the same then there's only the width of the bearing to consider. I don't know about the Hope but I think the Enduro bearings are wider than the shimano ones.
Are they worth it? I don't know, they're still in my spares box waiting for my 2 year old shimano ones to give up!
Posted : 20/03/2010 9:58 am
Enduro do have Email
Their bearings are good but they are just bearings, just like HOPE are good.
Posted : 20/03/2010 10:45 am
 dale
have spoken to them and they do fit the hope cups so I may chance it they are about half the price of the hope replacement bearings so hope to get a year out of them
Posted : 20/03/2010 11:34 am
