Elixir CR
[Closed] Elixir CR
How good anyone? Thinking of treating myself to an upgrade over the Juicy 5 on little mmmbop.
Posted : 14/11/2011 10:10 pm
Love mine but they need a bleed and a piston lube from new to get the best out of them.
Read what coatesy has to say.
He,s spot on with it.
http://singletrackworld.com/forum/topic/elixir-cr-contact-point-adjust-question
Posted : 14/11/2011 10:28 pm
not had any problems with mine, had them just under a year.
Posted : 14/11/2011 10:40 pm
Constantly need bleeding, always need realigning and the o rings in the levers are rubbish.....look elsewhere if u want reliable brakes!
Posted : 14/11/2011 11:06 pm
mine have never given me any problems with lots of power
Posted : 14/11/2011 11:09 pm
Only had mine for a few months, but in that time they've been faultless. Saw me through five days in the Alps without a single issue. Loads of power and great feel too - a noticeable step up from my old Formula OROs.
Posted : 15/11/2011 12:05 am
My rear caliper seized up last week. Noticed the pads were coming out - the retaining pin had fallen out. Took the pads out & gave the pistons a bit of a lube & now alls good again. And mine are a couple of years old. Great stopping power. Bleeding was very easy with the right kit. I'd buy again. More power than any of the Hopes I've had, X2's were very good though.
Posted : 15/11/2011 12:18 am
Love them, been using them on the salsa spearfish. And I think we are doing a pair of elixir 9 carbons for £264, which should make us the cheapest in Dorset, also the uk and maybe even in the eurovision.
Posted : 15/11/2011 1:03 am
I was thinking of going 2012 X7 or X9 instead....
Posted : 15/11/2011 8:06 am
Hey can anyone help me identify which adapters I need to run the new Elixir X9? I run Pikes up front 20mm and want an 8in IS on rear.
Posted : 15/11/2011 9:03 pm
no problems with mine, and a big increase in power and modulation over my previous Juicy 7s
nearly 3 years old, been all over the globe doing big descents and no problems with power / fading
if bled properly (many cannot do this - its not their fault, Avid Elixir CRs are tricky to bleed compared to the cheaper Juicy, Elixir R or Elixir 5) you won't have issues, and despite popular opinion they don't need regular rebleeding (this is only caused by bad bleeding)
last week I rebuilt my rear brake with new pistons / seals as the back brake had gotten a little noisy and tended to drag - the pistons were worn
after a rebuild with DOT rebuild grease (high temp silicon) and a bleed with DOT 5.1 and some new pads, the brake feels silky smooth and works great
today, I did a brake-dragging descent of the "wrong side" of Ivinghoe beacon and my brakes were smoking at the bottom, but kept the bike under control with no fading, and this is only using 160mm rear and 185mm front
from time to time, I have had problem Elixirs through my workshop, but this happens with any mass produced product being made in 1000s of units 😉
Posted : 15/11/2011 9:27 pm
Posted : 15/11/2011 10:02 pm
