I've seen so many threads on this. I've already got a proper Lumi LED3 unit but also have my 2 old halogen cans and a battery that I use for a headlamp.
I'm not competent to do my own conversion, but would anyone like to do one for me? Obviously, I'd buy the bits you need to do it and pay you for the conversion - either cash, or alternatively you can have my second can for your own version as a part payment too.
anyone?
using the cutter kit it is fairly simple to do. a realistic cost for doing it would make it prohibitive however. I did one for someone and it took me 3 or 4 hours - partly 'cos I had to cut a disc of alloy to mount it by hand.
Its really is not complex - just fiddly.
As TJ says electrically simple - 2 wires from battery to control board, 2 wires from control board to LED board & 2 wires from control board to switch if you're not using the board mounted option.
Can be fiddly though if you've got fat fingers!
that's what worries me. Fat fingers / no talent / electricity / on my head = strange tingly burning sensation / lack of hair.
be careful with the cutter kits - the budget one now uses a square board which I believe doesn't fit in the lumi halogen cans.
I asked the same question earlier.
Someone said they would confirm the bits I needed.
As to building - prob let me old man have a go.
Will let you know how it works out.
J.
Some good how to guides here http://www.candlepowerforums.com/vb/forumdisplay.php?f=86
This one is particularly detailed
http://www.geocities.com/telescopiman/MC_E_Blog.html
