I have a DT M1600 wheel set with front centre lock 15mm hub, which I believe is based upon the DT 340 hub. Does anyone know if you can convert the hub to either QR or 20mm axle? I was bought these wheels as a present but have 20mm forks ๐
Posted : 01/02/2013 8:24 am
Hey there, think you may be able to go down (if adaptors arr still available), but maybe not up if there owt like 240's. (or most other dt hubs) You'll probably be limited by bearing size. Give pace (uk service agents) a ring tho and they'll confirm.
Posted : 01/02/2013 9:19 am
Thanks. Had a reply from Madison who say the hub isn't convertible, only the 350 and 240 are. So looks like either new forks or new wheels. I have emailed Pace as well just to double check
Posted : 01/02/2013 10:56 am
