DT swiss 350 frewhe...
[Closed] DT swiss 350 frewheel conversion questions
Hi all, I'm about to swap the stock XD freewheel on a DT swiss 350 for a Shimano 11 speed.
Will I need to re dish the wheel?
Is a spacer required to fit the Sram 10 speed cassette on the 11 speed Shimano freewheel?
Thanks in advance
Posted : 28/02/2017 9:58 pm
No you don't. The axle sits in the same place in the dropouts and so will the rim/tyre.
C
Posted : 28/02/2017 10:31 pm
Nope,pull the freehub off, put the other one on.
Assuming you have the right end caps as an xd driver end cap is not the same as a Shimano end cap.
Nothing else needed from a spacer/redish perspecive
Posted : 28/02/2017 10:33 pm
Yup, I got caught out by the endcap. It's a 20 second job to edit the old one down in a lathe, you could do it by hand easily enough but all in all it makes more sense to just have the right endcap ๐Ÿ˜†
Posted : 28/02/2017 10:36 pm
That depends on the spacer... if you've got the 11 speed road freehub body, then you will need a 1mm spacer. The freehub body said 11 speed road on it in that instance. If it's the MTB 10/11 speed one then no etching and no spacer needed.
Posted : 28/02/2017 10:38 pm
 Bolt
As above just a straight swap on a mtb hub but the flange on the endcap is smaller on the xd one.
Am looking for an xd freewheel if you want to sell? Or swap for a shimano one?
Posted : 01/03/2017 8:10 am
Oh you're going from XD! I didn't notice that. The end cap is actually backwards compatible but you lose a little weather protection as it doesn't shield the bearing as well. And if you're selling the hub the buyer'll want it. So it still makes sense to swap, it just won't leave you stuck at 10pm the night before a ride.
Posted : 01/03/2017 10:16 am
Cheers all.
I am going from XD to 11 speed Shimano MTB freewheel, the endcap comes with the new freewheel.
@Bolt, already ordered the new freewheel, I'll keep the XD in case I change bike.
Posted : 01/03/2017 7:23 pm
