Dropper seatpost on...
[Closed] Dropper seatpost on a hardtail?
14 Users
hi all
spec'ing out my new hardtail, and trying to decide between a normal seatpost or dropper, will be used for mainly singletrack, no big jumps.
never used a dropper on a hardtail, any suggestions to if it's worth it, or should I just stick to a standard one?
TIA
Posted : 18/11/2011 11:37 am
why does it make a difference if its a hardtail?
Do it, it'll change the way you ride.
Posted : 18/11/2011 11:41 am
More usefull on a HT IMO.
Posted : 18/11/2011 11:49 am
If you already drop your seatpost now, then yes. If you don't ever drop your seatpost, then start dropping it!
Posted : 18/11/2011 11:52 am
looks like a droper it is. thanks
Posted : 18/11/2011 12:18 pm
I agree, with a hardtail you get bounced about more so it's nice to be able to drop the saddle and lower you centre of gravity to suck up the bumps.
Posted : 18/11/2011 12:37 pm
definitely yes. a hardtail pedals better, so it is worth having your seat post nice and high to make the most of that. which will mean you will want to be able to get it out of your way when it starts smacking you in the ass when it gets rocky.
so you should buy one
Posted : 18/11/2011 12:39 pm
Genuine quick q and no hijack intended - do m/any of you who use droppers on a HT drop the seat over just 20-50yds or so of really rough trail?
Interesting point. I'd only ever considered one for trails with 'proper' downhill sections or rolling tech trails.
Posted : 18/11/2011 4:26 pm
Ive got a dropper and now find I drop it for all sorts of bits of the trail. Irrespective of the length.
Basically if dropping it means I ride if faster / safer or makes it more fun, then I drop it.
That can happen for scary DH bits, techy bits, jumpy bits or even very twisty bits where tipping the bike over to corner faster is eaiser with a low saddle.
Its a remote dropper, so you can have it up/down in less than a second. Therefore you can really drop for just 10 yards.
Once you get one you will wonder why you spent so long without one.
Posted : 18/11/2011 4:42 pm
Jameso, one of the nice things about having an uppy-downy post with a bar-mounted control is that you can drop the saddle just for any bits that need it, rather than having to either run it dropped for long periods where you're pedalling because of a short technical section or have it too high for a techy bit because there's pedally bits before and/or after it.
Posted : 18/11/2011 4:43 pm
thanks a lot guys, youve just convince me to spunk another £150... 🙄
Posted : 18/11/2011 4:45 pm
And if one was to buy one which represents the best value + bomproofability Yes i just made up an new word) - in STW users opinion ??
Seems Gravity Dropper gets a load of votes for reliability. Also one of the few choices if you happen to have a 27.2 seatpost size.
I've got one on my 456 and I love it 🙂
APF
Posted : 18/11/2011 4:47 pm
Thanks.
Posted : 18/11/2011 6:06 pm
I have a Gravity dropper on Dialled PA, well worth it! 🙂
Posted : 18/11/2011 6:55 pm
Here you go. GD on a 456 Summer Season, well worth it. I've only had to replace the remote cable in over 12 months of use,no problems apart from that. 😉
Posted : 18/11/2011 7:18 pm
