Recently got a KS Lev for my Canyon Nerve AM.
I like the (sort of) subtlety of the Lev - remote replaces a lock on grip and cable mounts to the base of the post. The frame also has internal rear gear shifter cable routing, subtle brake hose routing down the down tube and currently running 1x10 for a cleaner look.
I've got a spare hole in the frame to run a cable down the inside of the down tube and up the seat tube, but the dropper cable isn't long enough.
Plan is to route it along the bottom of the top tube. However, mounting is a problem as I don't want to just stick cable ties all over my frame.
There are threaded holes in the bottom of the top tube (unfortunately a little too small to fit the cable through). Can you get threaded cable guides that I could stick in the to route the dropper cable? Like the little clips that hold the rear brake hose to the frame?
Why not just use a longer cable?
It's the only cable that came with the post.
I'm not sure the cable will fit in the hole into the frame due to the cabe housing anyway so I think under the top tube is the best route, just unsure how to mount it.
Just buy some gear cable outer and an inner wire.
They use standard 4mm cable so it's easy to change.
