Drilling the b.b sh...
[Closed] Drilling the b.b shell on a 2015 Spesh' Enduro. Anyone else done it?
Its the only way I can see of running a stealth 150mm dropper post on that frame, obviously it'll only be part stealth this way but at least i'd be able to use the dropper post.
Any STW collective thoughts on this?
Posted : 29/11/2017 6:20 pm
Have a look at the 2015 carbon frames. My dropper cable runs under the down tube. The cable clamps are designed for a dropper cable and then it goes through a hole near the bottom, if there is no hole on yours in that area you should be OK. There is a drain hole under the bottom bracket on mine which was helitaped over so I just cut the tape to stop the water settling
Posted : 29/11/2017 6:36 pm
On my older 2013 enduro carbon , it’s a very similar front end.
I drilled out the lowest of the rivnuts for the last cable clamp and ran the dropper cable up from there.
But thought the 2015 would have the hole already just past the lowest cable clamp just as above
Posted : 29/11/2017 8:28 pm
Found the hole! Its actually under the 3rd clamp down. Who knew? Well not me 😀
Thanks for the replies
Posted : 29/11/2017 9:11 pm
