Drilling holes in f...
[Closed] Drilling holes in frame for bike rack?
I've got a steel hack road bike (track ends) which lacks pannier rack mounts.
Could I get away with just drilling and tapping a hole (M4?) in each side? Or will the frame explode?
Posted : 05/03/2012 11:16 am
 cp
you'll be fine, as long as you are putting them in the plate material of the drop outs rather than in a frame tube.
Posted : 05/03/2012 11:18 am
Just get some p-clips.
Posted : 05/03/2012 11:28 am
p-clips won't take any weight.
M5 is the standard, should be fine if you leave enough meat around it.
Posted : 05/03/2012 11:29 am
Steel P-Clips are strong.
you could also attached to the wheel axle (you can get/make adapters)
but if dropouts are chunky drill and tape M5 will be ok
Posted : 05/03/2012 11:31 am
p clips work fine if decent quality ones carefully used. However if there is enough metal a proper threaded mount is better
Posted : 05/03/2012 11:32 am
One of the err...dudes on Pinkbike's epic Scott Voltage thread http://www.pinkbike.com/forum/listcomments/?threadid=81521 has drilled the head tube and BB shell to fit internal cables.
Posted : 05/03/2012 11:49 am
The alternative to P clips I used to use for a lower mount are these: http://www.cyclesurgery.com/blackburn%20custom%20eyelet%20kit/racks/bikes-components-bikewear/fcp-product/15897 - they fit into the triangular hole in old-fashioned dropouts.
Posted : 05/03/2012 12:05 pm
I've used p-clips with a load on a rack and they did not hold, strength is not the issue, it's sliding down the stay that is the problem.
Posted : 05/03/2012 12:07 pm
So put them at the bottom of the stay?
Posted : 05/03/2012 12:08 pm
perhaps they were too big?
Posted : 05/03/2012 7:06 pm
If its a rear rack you're wanting to fit you could get one of the topeak racks which clamp to the seat post only. They also have the excellent mtx-quick-track with corresponding bags that slide onto the racks
Posted : 05/03/2012 7:43 pm
