As the world seems to be sold out of UST screamers is there an alternative? Any help would be most appreciated. Anyone who says stick a tube in a regular wetscream will be ignored.
Lots of love
Vegi
swampies?
it has to be proper nasty for screamers to really come into there own, if its that gopping then i generally don't bother.
as jambo said,
has to be mental muddy to be worth running wet screams, swamp things for general winter dh dutie's.
schwalbe do the muddy mary...
I did try swampies for a bit, but i feel much more comfortable on a spike. Its probably worth mentioning that im a HUGE spike fan. I run F:Half cut down R:Full cut down in the dry, and F:Full spike R:Half cut in the wet. I also (but rarely) use minion DHFs F+R in the dry. So really im looking for a UST wetscream, but not a maxxis cus they are sold out.
Also id like the moon on a stick if you've got one going spare.
why the hell would you run wet screams in the dry?
even cut down ones will give you much less grip in the dry than a high roller/minion!
Michelin Mud 3 - probably even harder to get hold of than any of the above.
I have 2 unused in my garage ready for this winter and I love them... apart from the nearly 1.5kg weight.
Not a UST tyre but I run them that way with no problems.
Thanks Messiah, do you run them on tubeless rims or with a tubeless kit. (Stans etc.)
Dual ply maxxis tyres work fine for tubeless. I've used loads of them on UST rims, ghetto and Bontrager tubeless wheels. Make sure you use a latex based sealant like stans if you do this.
