down load a gpx to ...
[Closed] down load a gpx to garmin off t net?
7 Users
never done it ,a bit thick and no patience ? should try is it difficult
Posted : 17/07/2014 8:18 pm
Download the gpx to your PC and then move it to the Garmin
Posted : 17/07/2014 8:25 pm
 rob
Just pop the downloaded gpx file in the new files folder on your garmin
Posted : 17/07/2014 8:45 pm
 pt81
Hum that depends which garmin. The 205/305 dont except gpx files.
Posted : 18/07/2014 6:33 am
You could convert to tcx if your Garmin doesn't take gpx. The tcx will overlay your map with a visual route whereas the gpx will give you turn-by-turn guidance. Pros and cons to both.
Posted : 18/07/2014 7:55 am
The 205/305 don't except gpx files.
Mine does. You're doing it wrong.
Posted : 18/07/2014 8:18 am
 pt81
Be interested to know how. 😉 i've allways convertef my gpx files to tcx or crs with gpsies.
Posted : 18/07/2014 8:52 am
I've recently bought an 810 and downloaded 3 .gpx files so far, easy to do, but I run them through Connect first then load to the 810.
From what I've read on the Garmin forum it's really easy to just link the device to your PC/MAC then move the file over to the New Files folder, but I've yet to do this.
Posted : 18/07/2014 8:58 am
its not happening ? where do i find new files folder ,i have tried to manually up load ? help I'm a dummy 😳
Posted : 18/07/2014 9:14 am
Be interested to know how. i've allways convertef my gpx files to tcx or crs with gpsies.
I use a program called [url= http://www.loadmytracks.com/ ]Load My Tracks[/url] on my mac but there will be tons of equivalents.
I wonder if you are getting your model numbers mixed up though, as according to [url= http://developer.garmin.com/web-device/garmin-communicator-plugin/device-support-matrix/ ]this[/url], the Edge 205/305 take gpx & tcx and not crs.
 pt81
The (my?) edge 205 dont support gpx files , it reads and creates tcx ( course history) and crs ( older version of course history )
Posted : 18/07/2014 11:02 am
What model Garmin is it?
Posted : 18/07/2014 11:21 am
My Garmin is a 510 and i am using a Mac book pro 2014
Posted : 18/07/2014 11:46 am
The link I include in my last post...
...would suggest that Garmin disagree with you (as do I as I read/write gpx several time a week on my Edge 205)
Posted : 18/07/2014 12:27 pm
Can't help with the Mac bit really
but ........If you go into whatever the Mac version of Windows Explorer is - Finder?
and look at the Garmin
In there is another folder call 'Garmin' and in that folder is a folder called 'New Files'
Posted : 18/07/2014 4:08 pm
