Done with High Roll...
[Closed] Done with High Rollers. What Now?
6 Users
A few questions for the hive-mind.
I've been ripping the shoulder knobs off my High Roller 2 (2.4 3C Exo jobbies) so want to replace them with something a bit more... erm, stable. They need to cope with some NZ summer missions and should last me for a trip to Nepal next year.
I think I kinda liked the HR2s when they were holding together OK and a lot of tyres seem to be cut from a similar mould/concept these days.
Minions seem the obvious choice but is 2.3 or 2.5 more suitable for a front? I heard the mion casing comes up a bit smaller than HR, but looking at flat folded tyres in a shop this avro seemed to contradict this. Maybe they fixed it with the Minion DHF 2?
The Ardent 2.2 looks weedy and the 2.4 has a lot more material on the tread but isn't the Ardent casing huge?
I've heard the Hans Dampf suffers from breaking away side knobs too, so I should probably avoid them. I have a pair of Magic Mary (supergravity, 1 x verstar, 1 x trailstar) which would be a great front tyre, but they're heavy and drag. I could pair one up with a Rock Razor or something to get some silly speeds going.... but might have to just suffer the weight and get ripped 😀
No one local in NZ seems to stock the Mavic options so I've never seen them on the trails..
What else could I consider?
p.s. 650b has narrowed my options 😡
TL;DR - recommend me what tyres you are currently using (actually, please don't)
Posted : 28/10/2014 8:57 am
It's the 3c that's the issue not the hrs. Minions only come in 3c I think so they won't help. Try hr2 dual compound, or wmb vigilantes for harder wearing tyres.
Posted : 28/10/2014 9:05 am
Is it? The Minion side knobs are much more substatial than the HR's.
Posted : 28/10/2014 9:11 am
 duir
They also do a dual 60a/62a compound in 2.3 which is pretty much the same size as the old 2.5 and good for a rear tyre. That tyre is faster rolling and tough as old boots in EXO version. There is also the 2.5 super tacky which in EXO is also very tough.
Posted : 28/10/2014 9:17 am
Hans Dampfs are not a tough tyre, they fall apart surprisingly easily.
I'm on WTB Bronsons now, the Vigilante maybe looks more like what you're after?
Posted : 28/10/2014 9:21 am
Vigilante's looks ok. A few comments about the weak sidewalls, but the weight looks like they ought to be better than paper-thin.
Posted : 28/10/2014 9:29 am
If you're wrecking Maxxis, don't go near Schwalbe. As I saw somewhere else, they last as long as a cheap firework display. Kinda reflects my experience too.
Posted : 28/10/2014 9:31 am
My 3c 2.3 DHRII which is on the rear is starting to show signs of wear earlier than I would expect. 2.5 DHF 3c on the front is still in perfect condition.
Posted : 28/10/2014 9:43 am
