Does this sound sen...
[Closed] Does this sound sensible?
8 Users
I’ve got a trusty Cannondale 900sx which has served me well for the past 8 or 9 years. A new s-works last year has meant this is in a state of early retirement so I’m thinking about re-building it into a commuter.
Plan is to build a set of 700c wheels and run a road tyre – is this likely to fit under the lefty? And will a lefty hub present a problem to the wheel builder? (will it fit a wheel building jig)
In terms of drivetrain I was thinking a roadie close ratio cassette with road biased chainrings – possibly something like an Ultegra triple chainset. Will my LX shifter pods pull the right amount of cable to shift roadie cogs?
Anything else to consider??
Posted : 05/02/2009 10:23 pm
You will need an adaptor for the wheel jig. I have one you can borrow if you are in the BS37 area.
Posted : 05/02/2009 10:29 pm
it sounds like madness, why not eh?
Posted : 05/02/2009 10:30 pm
peteimpreza - thanks for the offer but i'm afraid i'm some distance from Bristol. are the adapters expensive?
Posted : 06/02/2009 4:12 pm
mmm.... good excuse to build your own wheel, no? Shouldn't be too difficult, although I guess there might be some dish. £10 for Roger Musson's book, DT Swiss spoke calculator jobby, bish bash bosh!
Posted : 06/02/2009 4:14 pm
It sounds like a lot of expense for very little gain. Much more cost effective to leave the wheels as they are and simply fit something like Conti Sport Contacts then simply swap out the chainrings for 48-36-26 (or get a new chainset if that is cheaper). Road cassette on the back if you want closer ratios.
Posted : 06/02/2009 4:19 pm
 JoB
as above, i'd simply put some 26" slicks on and swap the cassette for a road one, no need to change the wheel size or put a roadie chainset on (possible clearance issues there anyway)
Posted : 06/02/2009 4:24 pm
i've got specialized fatboys at the moment and aside from being a bit scary in the wet they roll nicely. problem is really down to the space between gears and the relatively low top end. might start with a change to road spec cassette and rings and see how that feels
Posted : 06/02/2009 4:26 pm
ah, hadnt considered clearance on a road chainset.
Posted : 06/02/2009 4:28 pm
petrieboy - Member
Got mine off ebay. I'll try and find the seller.
Posted : 06/02/2009 4:29 pm
peteimpreza - Member
Found this while looking for the hub adapter
29"/700c conversion for Lefty
whic i guess answers the question of whether a 29er will fit under a lefty. looks like ill be sticking with 26" rims then!
Posted : 06/02/2009 11:45 pm
you should be able to get the travel adapter in the UK if its an offical cannondale part
lefty max need a simple plastic spacer
Posted : 08/02/2009 12:10 pm
I got the official Cannondale truing axle from a LBS. £11. I'd built the wheel, and they wanted to charge £20 just to true the bastard!!!
Posted : 08/02/2009 12:18 pm
