Does this show worn...
[Closed] Does this show worn fork bushes?
Gently rocking the bike back and forth with front brake applied - slight knocking sound and movement? Headset isn't loose and forks aren't extending/compressing.
Posted : 31/01/2009 7:55 pm
What fork?
Posted : 31/01/2009 7:56 pm
If you have disk brakes check its not the pads moveing
Posted : 31/01/2009 7:57 pm
Vanilla
turn the wheel 90degrees and try again (that should isolate any pad movement)
Posted : 31/01/2009 8:16 pm
Try storing the bike upside down for a while to let the bushes in the top of soak some oil up.
Posted : 31/01/2009 8:18 pm
if you wrap your hand around the seal on one leg and rock again you'll feel the movement there if it's the bushes
Posted : 31/01/2009 8:21 pm
Thanks all
Posted : 31/01/2009 8:22 pm
May just be the pads moving in the caliper. Pull the brake lever on as hard as possible, to stop any pad movement, and try again.
Posted : 31/01/2009 10:51 pm
 Doug
Also check your front wheel bearings, brake caliper mounting bolts and rear shock bushes.
Posted : 31/01/2009 11:00 pm
