Or should I put some bolts in to stop water getting in frame?
I use nylon grub screws, because they weigh nothing and cost basically nothing, I like this sort of bullshit.
Odd as I'm debating drilling a hole on the underside of the bb shell on a frame I'm building up! Lol
Pity we can't trade, erm, holes.
What material is the frame?
Plastic grub screws. eh?
A hilarious riding companion would never think to screw those all the way through to rattle about forevermore while you're not looking ๐
Do it and I will cut you
Poopscoop - MemberPity we can't trade, erm, holes.
Outies and innies are different
Hot glue.
oxym0r0n - Member
Mine or op's mate?
Mines alloy. Don't like the thought of a pool of water sloshing about with no where to drain from. Probably being a bit OCD though.
Op's ๐
Lol ๐
๐
Ok well let's say one frame is steel, the other ally
One set of forks steel the other set carbon
Leave the holes empty in the steel stuff?
What kind of monster even jokes about this?
Ok well let's say one frame is steel, the other allyOne set of forks steel the other set carbon
I would certainly plug the holes on the steel frame if water could get in and cause rust...
