I need0a six bolt adaptor with six holes in that are rotor bolt size rather than the common type that have grub screws attached that are bigger than rotor bolts. THanks
It's not necessary to have another adapter. The shimano one attaches to the rotor, turning it into a centerlock one.
Here's the techdoc
And a link to a decent price:
http://www.cyclebasket.com/products.php?plid=m9b14s287p1892
Ssb that might work
Andy I have one of those it won't work
It's for a six bolt mount fixed cog I have holes are as big as rotor bolts but not as big as rotor holes. So its proving a bit of a problem . I need a bolt on adaptor I can Just fasten rotor bolts in to
I'm not convinced there is something that does that. Sounds odd. I thought you wanted to use a normal rotor on a centerlock hub.
What about the DT one?
[img] http://www.dtswiss.com/getdoc/cd1f3361-0812-403f-8312-d00761632fe8/ProductImage.aspx?maxsidesize=520 [/img]
I've got an unused pair I'd be happy to part with!
That DTSwiss one looks just the job.
the mavic ones are the same as well and they come with the wheels so you might pick one up cheap
