Does anyone make......
[Closed] Does anyone make....
A 10 speed cassette with 10-36 or 10-40 sprocket spread?
I think Hope were developing one but I can't find one for sale.
Posted : 06/06/2017 1:35 pm
Yep, 11-42 from Sunrace, its a nice piece of kit.
Posted : 06/06/2017 1:49 pm
Yes I've seen those but its the 10t top gear I'm after.
Posted : 06/06/2017 2:41 pm
If you want 10-40t but can only get 11-42t, just run a slightly bigger chainring?
Posted : 06/06/2017 2:44 pm
^exactly..
Posted : 06/06/2017 2:45 pm
Diameter of a 10t cog is too small for a standard freehub, so you're into new freehub territory, and at that point it's probbly cheaper to go 1x11
Posted : 06/06/2017 2:47 pm
E13 do a 9-42:
[url= https://bythehive.com/collections/drivetrain/products/trs-cassette ]Not cheap though[/url]
Posted : 06/06/2017 2:48 pm
No can do (any bigger will foul the chainstay)
E13 do a 9-42:
Not cheap though
Its an option but 9t brings the chain very close to the chainstay as it comes off the sprocket.
Posted : 06/06/2017 6:08 pm
You'd almost get a GX 1x11 kit and freehub for the price of the E13 cassette
Posted : 06/06/2017 6:56 pm
If you've got a dt swiss hub there's a One up conversion that allows 10t. But I've thought it expensive and i've not been found wanting anything bigger than 34 x 11.
Posted : 06/06/2017 10:30 pm
Oneup kit is for 11s
Posted : 06/06/2017 10:38 pm
New bike
Posted : 06/06/2017 10:40 pm
@Stevied...still not received mine....10 weeks now. #worstbikeshopever
Posted : 06/06/2017 11:54 pm
Yes that's to much for a cassette.
Posted : 07/06/2017 4:28 pm
What cranks and front ring are you running? On what frame?
Can you space your spindle outboard on the driveside to make room? How's the current chainline?
Posted : 07/06/2017 4:58 pm
I'm replacing worn out XT 3x9 (worked fine clearance wise) with XTR 2x10 trying to keep 44-11 top gear using M985 cranks, I've got one spacer on the drive side of the 73mm bb (On one carbon 456 frame) but the big ring touches the chainstay, if I can find a 10-40 cassette I can use a 40t chainring to get the same top gear.
I can't fit more than the one spacer I'm already using.
Chainline appears fine (using the 40t chainring)
Posted : 07/06/2017 6:08 pm
I'd just bang an extra spacer on the drive side
Posted : 07/06/2017 6:11 pm
Could you not just pedal a bit faster?
Posted : 07/06/2017 6:19 pm
 Bez
People actually need 44x11 on mountain bikes? Wow.
Posted : 07/06/2017 6:51 pm
I'm more intruiged by what the smallest gear combo in the granny will be
Posted : 07/06/2017 7:05 pm
Just a bit worried about trashing some expensive cranks.
Posted : 07/06/2017 7:59 pm
whats the measurement from inner crank arm face to rim outer on both sides?
I literally throw spacer info out and try to get cranks equidistant from wheel center with the best chainline. You could easily be a 1/4 inch out already
Posted : 07/06/2017 11:17 pm
Not sure how you can do this with HT2 on a 73mm bb - one spacer on the drive side already, anymore & I'm exceeding the recommended - even adding an extra spacer only gives me 2.5mm max & I'm not sure that's enough to stop the contact while standing pedaling & also reducing the amount of spline interface for clamping the NDS crank arm risking trashing them.
Posted : 08/06/2017 7:10 am
44/11 - do you really need to be geared to do 38mph with reasonable cadence?
Posted : 08/06/2017 7:17 am
30t chainring 40t rear
Posted : 21/07/2017 6:44 pm
How much for sunrace/SRAM 11sp upgrade?
Posted : 21/07/2017 6:53 pm
