It's an old SS and takes a sturmey Archer type sprocket. Is it held on by a circlip? There appears to be some sort of dust cap or cover screw with three indents. So how do I remove the sprocket to change it?
SA gearhub sprockets are held on only with the circlip. The three prongs are just spline guides I think.
"takes a sturmey archer style sprocket" WTF
pics needed
How do you remove the clip (and put it back on)?
flat bladed screw driver and a lexicon of swear words.
Use a punch to make sure it's reseated properly when you reinstall.
Same as the Alfine although SA sprockets are slightly too thick to fit.
There appears to be 2 sizes of SA sprocket 1/8th and 3/32s. I've assumed my hub (not SA) takes 1/8th, but that's a guess and the new sprocket was only £3 so no great loss if it's wrong.
Thanks for the advice Stoner
banana - ive got some spare SA sprockets at home in the shed. If you find yours doesnt fit, I may have a 3/32 you can have gratis but I need to check w the verniers. Drop me a line if you need to.
EDIT: BTW dont forget you have the ability to adjust the chainline to some extent by flipping the sprocket over and using the pressing offset. (16T and larger anway - smaller ones arent dished)
Thanks Stoner, I have a 36t chainring, so I've ordered a 16t sprocket which might give the right SS ratio for my canal bank commute to work.
