GF dragged her was dragging a bit last week and as such her rear is a bit squidgy.
can i put together a bleed kit from chemist or diy store to give her [i]brake[/i] a flush?
epicbleedsolutions do a cheap one
I was talking to a mate about avid bleeding as he runs their kit and i have some to fit.
His opinion is that the 10-11 quid kit on fleabay does the job as well as the Avid original.
The key is supposedly the little valve fittings and the plasticky 'pipe clamps' (that turn the bleed hose to/from the syringe into a one-way valve with manual intervention). The rest (ie, DOT 5.1, gloves, syringes and pipe) you could scare up really easily, but a small amount of brake fluid is worth buying.
It is worth noting that brake fluid is best bought in only the size bottle you plan to use right now. Apart from Shimano-style mineral (i think) and DOT 5.0 (*NOT* compatible with anything else, ever) brake fluid absorbs water from the air as soon as you open the container, so buying that £10 5l can cos it'll last for ever is a poor move if you like your brakes without pressure locks from boiled water... For some reason brake fluid becomes wildly more expensive per amount the less you buy... the smallest bottle in Halfords' is probably at least 4 quid before you start on the rest of the bits.
It's the syringes you really need, got mine from EBay for pence. The tubing you can get from an aquarium shop. Boots might have the syringes. Ikea do the tube clamps in the form of kitchen food bag clamps.
I've got an Avid bleed kit I bought off here but didn't use.
You're welcome to it for a tenner posted.
MIP
thanks barn, but i'm in Germany.... postage a bit of a pain.
i'll look on the Bay.
cheers
50% true, but in reality brake fluid in a sealed bottle won't absorb moisture, just look at the reservoir in most car's, there's no seal on it at all, mine even has a vent hole in the top to allow air in and out!
I'd probably not trust a 10 year old bottle but it'll be fine for a few years.
The ones on ebay for 7.75 have a hex nut on the end and it doesn't fit inside the lever end recess and so doesn't seal. It can be got around by adding a second 0 ring. The ones for a tenner have slimmer ends that would fit inside the lever and seal.
Otherwise the cheap ones seem to work as well as the Avid.
barn - MemberI've got an Avid bleed kit I bought off here but didn't use.
You're welcome to it for a tenner posted.MIP
Posted 2 hours ago # Report-Post
🙂 Being cheeky, as I am sometimes, are you still interested in selling this since alpin's not able to take you up on it?
I used these guys - www.bleedkits.co.uk their kit at £11.25 comes with fluid. They delivered free as well
