DIY taco only bash
[Closed] DIY taco only bash
I'm thinking about knocking together a taco style bash from a single piece of polycarbonate that will mount directly on to the iscg mounts being as no one seems to be making one yet.
It's for a 456 evo set up 1 x 10 to protect the ludicrously expensive NW chainring. I know I could just use a bash as I always have in the past, but i just fancy a taco for reasons of vanity.
Only possible issue i can think of is any impact will be transmitted directly to the mounts rather that via a backing plate like on a normal taco/guide combo. Reckon it'll matter?
Posted : 13/01/2014 8:55 pm
Unless the force bends the backing plate, it's going to end up at the mounts anyway, so I wouldn't have thought so.
Posted : 13/01/2014 9:23 pm
Is this not what you are after?
http://www.mountainracingproducts.com/mrp/xcg/
Posted : 13/01/2014 9:36 pm
Or [url= http://www.blackspire.com/BRUISER ]this[/url] Blackspire Bruiser
Posted : 13/01/2014 9:52 pm
For whatever it's worth, my narrow/wide (not that expensive, £35) is wrapped in steel for protection 😉
I had the old MRP taco thing for a while, but noticed that the Gamut bashring I had lying around was actually lighter, and looked better.
Posted : 13/01/2014 10:12 pm
Ah ha that is what I was after, just a bit more compact as I only need cover 30T ring.
Gonna go the DIY route I reckon.
Just thought as well, the bolts thread directly into the raceface ring, so how do you a bash with it? Have to get extra long chainring bolts?
Posted : 13/01/2014 10:54 pm
