This is one for Trout or any other LED boffins out there.
Can i run a 4 XPG light off a 14.8V battery through a maxflex driver or will the driver be out of regulation and leds burn out? If i change the driver to the b2flex or another 'buck' driver and is there enough of a margin between the LED forward voltage at 1500mA and the 14.8v battery?
Also doesn anyone know of any buck drivers that give atleast two different current outputs or are the taskled ones the only option or does anyone have a space b2flex driver they'd be willing to sell?
Thanks
I run that exact set-up with no problem and have done for the past 3 years using both XRE and XPG LED's.
I am also looking for a Bflex as well if anybody has any spare.
Blackcat off Ebay will do a dual power driver if you don't wnatn a Bflex
Errr.
If Vf of 4 x XPG is ~14.8v and the battery off the charger may be as much as 16v and over.
Then the Maxflex won't work as it is a [b]boost[/b] driver and needs the Vf in to be lower than the Vf out.
Yes you can but as the battery drains it will go direct drive and dim a little .
no big problem there .
Yes I have lots of B2flexs but if you want one you will have to be quick as going away on hols tomorrow .
paypal gift me 32 dollars equivelent in our money plus a bit of postage and will get one in the post first thing int morning
Email in profile
Hi Trout I'll be in touch when you get back from holiday got to sort out a hope compatible power connector first.
Hi Chris (Trout) I don't need a bflex anymore as a friend has sorted one out for me as he is upgrading his lights. I was wondering if you used hirschmann connectors on your lights and if they are compatible with the hope screw on connectors If they are do you have any spare that you would be willing to sell me i need at least 1 preferably 2
Thanks
Yes I think the connectors are the same as the hope one Smudge says they are
got plenty instock drop me a mail with which ones you are after .
I'm after a panel mount socket like the one in the pic below
Let me knwo how much you want for two posted
cant post a pic but the part number is ELST 3308 RV FM 805
here is the link to the google pic jere is trying to get to show
Hi Chris (Trout) ygm about connectors
Hi Chris i've sent you an email about a bflex driver as i've knackered mine.
