Diy 900 lumen and 1...
[Closed] Diy 900 lumen and 1800 lumen kits
any interest in XML single led 900 lumen and double XML 1800 diy kits
housing. / leds /optic /driver / cable / bar mount
afraid you will need to make your own helmet mount
Posted : 25/02/2011 2:38 pm
oooh, maybe.... How mych you looking at for a single kit??
Posted : 25/02/2011 2:43 pm
yeap dependent on price But would be very interested in the 1800 kit
Posted : 25/02/2011 2:45 pm
Any links to piccies please.
Posted : 25/02/2011 3:11 pm
No details just yet. just a feeler and will be working on it over the weekend .
might get a few piccies tonight
John Climber is running the first proto on his helmet .
Posted : 25/02/2011 3:27 pm
Possibly. Might convert my Lupine stuff if the price is good, wiring is getting old.
Posted : 25/02/2011 3:33 pm
I maybe, depending on price 🙂
Posted : 25/02/2011 3:39 pm
I might be too
Posted : 25/02/2011 3:44 pm
+1 for me
Posted : 25/02/2011 3:45 pm
Me too for the 900 one, depending on price....
Posted : 25/02/2011 3:47 pm
+1 for both. Cheers Trout.
Posted : 25/02/2011 3:49 pm
 benz
Troutie, sounds like a good plan. Particularly interested in a nice little single. Happy to test up here....
Silly idea......900 kit ability to be fitted into a Lumi halogen housing?
FYI, I have a lumi HID can too....with a choice of 2 'robust' machined heatsinks. Expect a parcel soon....
S'later
Posted : 25/02/2011 4:02 pm
 mst
I'm looking for something that will fit into a Cateye stadium housing. Anyone got anything ?
Posted : 25/02/2011 4:20 pm
sound spot on Troutie, especially as benz says if you can get them as 35mm kits that will be great.
BTW did you get my mail form this morning ref XRE/XPG's and optics.
Ta
Dave
Posted : 25/02/2011 4:21 pm
 wors
Ooh yes. How much?
+1 for both...
 benz
Dave - I still need to slip those HID sinks in the post...I do it this weekend....
Posted : 25/02/2011 4:23 pm
Well if your going to have my 'hat light' 🙂
This sounds like a plan..
Guess what.yes depending on price
Posted : 25/02/2011 4:27 pm
I'd be seriously interested in the 1800 lumen kit.
Any chance of an even bigger kit? Not that I'd ever need it, but it would open up the ability to use a helmet cam at night!
What kind of power would it need? Would the 8V magicshine batteryw ork?
Posted : 25/02/2011 4:29 pm
Cheers Benz
 Del
presume this includes driver, LED(s), optic?
would have a better idea if you can provide:
'less than' price.
input voltage range.
but in principle, as it costs me nothing to say 'yes', yes!
Oh go on then, I'm interested.
Posted : 25/02/2011 4:53 pm
This is what they will most likely look like
they will be workable from the off but the builder may want to do some finishing work IE rounding off the corners and stuff like that .
the build will be pretty easy if you can solder and drill holes with a certain degree of accuracy .
of course there will be full instructions
ball park figures are
single diy light 900 lumens £75/£80
double a tad more
input voltages
single will run from 1 LiIon or multiples in parallel
3.7 volts
double will need a 7.4 volt pack
or with a more expensive driver the double can use any voltage up to 20v but no lower than 7.4 v
all drivers will have programmable modes at the click of the button
Posted : 25/02/2011 5:32 pm
Chris
I guess i'm away down your priorities at the moment,but i need to get the driver sorted one way or the order, my mate Gaz is without a light until we can sort something for him.
hope to here from you soon.
Paul
Posted : 25/02/2011 5:44 pm
+1 for single
Posted : 25/02/2011 5:47 pm
Speshpaul
YGM
Posted : 25/02/2011 5:53 pm
The double is good, lad in our club has one.
Posted : 25/02/2011 5:54 pm
can you bar mount the light
either was i'm interested in the double
Posted : 25/02/2011 8:13 pm
Double please
Posted : 25/02/2011 8:28 pm
Good Stuff 🙂 good to see plenty of light builders stepping up to "[i]the plate[/i]".
This may help too.
http://forums.mtbr.com/showthread.php?p=7661703&page=2
Posted : 25/02/2011 9:47 pm
Posted : 25/02/2011 9:55 pm
Trout strikes again 8)
I really enjoyed building the CK/Trout light so would definately be interested in both of these. Couple of quick questions, is the housing just flat or grooved and do you have any beam shots?
Posted : 25/02/2011 10:36 pm
the housing will be grooved it needs to be for the extra cooling if run at full throttle .
more pics to follow
beam shots will be along soon
Posted : 25/02/2011 11:14 pm
Id be interested in just a housing or two if that's possible?
Posted : 25/02/2011 11:43 pm
 Del
on that basis i'm in the market for one of each running off a lumi battery pack, so ~ 13 - 15V nominal.
Posted : 26/02/2011 12:40 am
Yep, I would definitely want a 1800 kit.
Posted : 26/02/2011 12:58 am
Very interested in the 1800 kit.
Iain
Posted : 26/02/2011 12:39 pm
Very interested in an 1800, ideally to use 13.2V battery as I have 3 of these.
Posted : 26/02/2011 11:41 pm
Rightio got one ready to build up well nearly
here is what will be in the kit
ref the driver the H6flex is for battery voltages over 8.4 volts and under 20 volts and is a pricier driver .
The Lflex is for the 8.4 volt batterys and will run off a DX Bastid
battery if needed and a DX cable is available from me or DX
You will need to be able to solder or have a mate that can
and drill a few holes IE switch and cable entry
also holes for screws to hold the leds down I will get some small self tappers and include in the kit for this purpose .
the housing will be raw aluminuim and need sanding and finishing off
if you want it to look a bit better
If I do it then it costs a bit more 😉
but if you are lazy you can just assemble it and go riding
I will have this one built today and get a beam shot tonight .
the single 900 lumen one will be half size and only use the Lflex driver and 3.7 volt battery
tools needed to build will be
soldering iron
drill and bits
wet and dry and fine wire wool if you wand to shine it up a bit .
screw driver
A Tube of this glue http://www.bostik.co.uk/diy/product/evo-stik/Serious-Glue/16 is one I have found to be an excellent and better product than silicon sealant
I will probably include a tube in the kit to keep it easy .
Posted : 27/02/2011 12:48 pm
does it need any arctic silver or the like?
I wish I didnt already have an LL - Id want to make up one of those.
Maybe I could go into business putting them together for people who want an easy life? 😉
Posted : 27/02/2011 1:21 pm
Arctic alumina or silver epoxy can be used to glue the led stars in place
instead of screws and compound forgot to mention thermal compound .
Posted : 27/02/2011 1:43 pm
Hi any idea on battery life for the 1800?
Posted : 27/02/2011 2:10 pm
Yep, very interested in the 1800 kit, especially with the upgrade on the case finish.
Ian
Posted : 27/02/2011 2:33 pm
edited
Posted : 27/02/2011 4:10 pm
Definitely interested in this! This actually looks do-able for an idiot like me :-).
Posted : 27/02/2011 4:27 pm
A quick run through a build sequence ( other peoples methods may vary )
You have got your housing all shiny and shaped to your liking .
it needs a thorough wash to get any swarf and grease off it
and you are ready to start .
as you see the 20 mm led star is 1 mm too big to fit top to bottom
so a careful filing is required being mega careful not to knock the led dome off remove enough ali so it fits snug but don't go right to the top and bottom solder pad as you don't want them to short on the case .
and before installing them in the case it is a good idea to tin the pads you are going to be using
next to install the leds I have used Arctic alumina epoxy for speed
but at £8 for a kit of the stuff you can drill and screw the stars to the heat sink and use some thermal paste .
then connect your feed wires and pass them through to the rear .
time to now fix the reflectors
use some of the serious glue and make a ring round the leds
being careful not to get any on the leds
and fit the reflectors making sure to seat them level and wait for the glue to set .
when it has set you can also fit the lexan cover using careful application of the glue around the ledge
and maybe a bead around after the lexan is in place for added waterproofing .
the Driver next and this applies to both H6flex and Lflex drivers
when soldering wires to them you must make sure they dont protrude out the bottom as the driver needs a flat base for the thermal adhesive tape provided to fix it in the housing
you will have drilled your backplate for the switch and what ever power entry you have chosen or bribed me to drill them I have used the Liberator connectors for this build .
now it gets a bit fiddly when the connections are made
remove on side of the protective covering and apply the tape to the driver base .
remove the other side and insert in the case in your desired position
the tape will not stick tight until you warm up the case with a hairdryer and carefully seat the driver flat .
it is important the driver is well seated as it needs to be kept cool also.
seal up the back with some of the glue and screws and job nearly done
you now need to configure your driver using the instructions on the www.taskled.com site
Posted : 27/02/2011 4:40 pm
 DeeW
Chris,
I'd be interested in a 1800 kit. Would be my 5th Troutie light!! Would seem a real shame to miss out on the next generation!
Am I right in thinking these are going to be fairly narrow so perfect for helmet light?
I'd be replacing my 3 x XPE R2 helmet light which although has a great throw, does gets pretty drowned out by my Liberator, but wouldn't want to lose the throw of the XPE. 1800 be roughly twice as bright as the XPE?
Dave
PS went for a ride a couple of weeks back with 6 Trout creations between 4 of us: got a local monopoly going on here!
Posted : 27/02/2011 6:19 pm
Nice, Chris!
Couple of Q's: Do you supply a piece of L angle or similar for the LED board? If so, do you supply the case with a tapped hole for the bar mount in the case or the L angle (or both)? Is this hole the primary means of holding the LED plate to the case?
Posted : 27/02/2011 6:47 pm
Dave
Yes they are a good helmet beam and OMG bright
beam shot when it gets dark tonight .
Bobblehat
no L angle in there it is an 8 mm thick lump of billet
and an interference fit with some paste for good measure forced in with a gert big vice and then the M4 tapped hole is drilled into it so it aint going anywhere .
Posted : 27/02/2011 7:20 pm
Looks great how do I order one? Thanks
Posted : 27/02/2011 7:27 pm
I kind of want one, I don't need one, but I want one...
Posted : 27/02/2011 7:35 pm
Thanks Chris, sounds good, looks good ..... tastes good and by golly it probably does you good as well! 🙂
It's the Mackeson Light!
Posted : 27/02/2011 8:21 pm
Beam shots at the MTBR settings
low approx 280 lumens runtime from a 2.6 amp hour 14.8 v battery
is approx 28 hours
medium approx 560 lumens runtime from same battery 8 hours approx
High approx 1800 lumens runtime as above battery 1 hour 40 mins
other levels are available if you need to tweak runtimes
Posted : 27/02/2011 9:19 pm
i love you
Posted : 27/02/2011 9:20 pm
Can you give me a price on a driver, LED's & reflectors please. Hopefully if you are buying in bulk this would be better than what I could get the hardware for.
cheers. (mail in profile)
Posted : 27/02/2011 9:22 pm
OK will have a workout tonight Evesie
which driver ?
Stuey. are you a fit female ?
Posted : 28/02/2011 9:21 am
I could be for you..
<<Has selling led light made you a multi millionaire yet ?>>
Is there a driver solution that allows for swapping between <8.4v and >8.4v ?
Posted : 28/02/2011 9:29 am
not realy for a doube xml set up.
H6Flex. for > 8.4. and. LFlex for. < 8.4.
Multi billionaire really with a girl in every town
Posted : 28/02/2011 9:37 am
Trout - Did I miss it, but how much would the double set up be?
I was looking at doing your 700 lumen lights...but now Im thinking!
Posted : 28/02/2011 9:51 am
will definatly have an 1800 kit from you
Posted : 28/02/2011 10:52 am
Is there a way of making the medium setting a bit higher? Say 1000 lumens ish for 4 hours ish on that battery?
Probably more useful for singletrack stuff like that, with the full setting just for faster downhills and foxhunting. 🙂
I'd take a kit if that were the case.
Posted : 28/02/2011 11:08 am
I'd definately be interested in an 1800 kit.
Posted : 28/02/2011 11:09 am
Slightly ot question, and you've probably done it already... but, how much longer would the casing of the single have to be to fit batteries in as well??
Posted : 28/02/2011 12:22 pm
 Del
put me down for a double then please.
i may take a few singles, with the H6 >8.4V drivers, w/o cases too, for conversions, if that's ok?
see how the numbers work out.
Posted : 28/02/2011 12:28 pm
These batteries seem like they would do the trick nicely!
[url= http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=16575 ]A123 from HobbyKing[/url]
Posted : 28/02/2011 1:33 pm
I'm interested in some loose xmls on stars if you could hook me up troutie?
Posted : 28/02/2011 1:43 pm
Battery wise I was wondering if this would do?
http://cgi.ebay.co.uk/12V-9800mAH-Portable-Li-ion-Rechargeable-Battery-Pack-/290532586412?pt=UK_ConsumerElectronics_Batteries_SM&hash=item43a51773ac
£30 but is it likely to fail and blow up!
Posted : 28/02/2011 1:50 pm
Another neat light there Mr T 8)
If anyone is after a purpose built 7.5V 4.4Ah Li-Ion Battery along with pouch, charger & mains lead.
I will also include a mating lead for the light head.
£63 inc p&p but limited availablility.
Please email me for more information.
Smudge
Posted : 28/02/2011 1:57 pm
Mr Trout,
LFlex please - I like nice small battery packs.
Posted : 28/02/2011 1:58 pm
Put me down for a 1800 lumen kit, with a driver for a 12v battery.
Posted : 28/02/2011 11:48 pm
I've got one of those. Works fine. Big old lump though. [url= http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=400161359813 ]This pouch is a good fit for it.[/url]
Posted : 28/02/2011 11:55 pm
Chris - your website is down and I [s]want[/s] need some of your finest lights.
What have you got that will burn for 4-5 hours and bring down small aircraft?
How much and how soon?
email me if you don't want to post up here.
Posted : 01/03/2011 2:24 pm
Put me down for a double running 15v please Chris.
Posted : 01/03/2011 3:02 pm
I will take a 1800 Lflex kit please .mail us with further instructions
Simon
Posted : 01/03/2011 11:40 pm
Interested in an 1800 with a H6Flex
Posted : 01/03/2011 11:43 pm
Forgot to mention in an earlier post that I'd want an Lflex driver with the 1800 kit.
Mail in profile.
Iain
Posted : 01/03/2011 11:49 pm
Hello peeps had a horrific few days working 18 hours a day and falling asleep as soon as I get home so sorry for disappearing.
got a price worked out for the double kits but with a change of optics as the reflector has a sharp cut off at the sides which I dont like so will be using Ledil Laura optics build will be just as easy so no worries there .
as said before the housings will be rough machined and you will need to do a bit of finishing on it
to build you will only need to get some thermal paste or thermal epoxy
everything else will be included in the kit .
I only have 2 of the H6flex`s in stock with more on order so will be a while before they arrive .
I have 15 of the Lflexs in stock with more on order.
prices are H6fex kit £95 posted ( battery > 8.4 volts )
Lflex kit £85 posted ( Battery 8.4 volts )
email me if you want one mail in profile
Posted : 02/03/2011 7:12 pm
Hi Chris, mail sent
Iain
Posted : 02/03/2011 7:26 pm
