Help A noob in distress
My disk brake piston (one of them) isn't seating itself properly back into 'hole' causing disk brake rub
if I removed the brake so it has no resistance & pump the brake leaver, it simply doesn't return to it's default position. They are not the greatest brakes, less than 4 months old & are hydralic
Why is this & what to do? I remove my wheels often? Dunno if that's anything to do with it? Just listing all the facts
thanks guys
Posted : 06/09/2010 7:39 am
clean the piston and lube it with the correct lube for your brakes - shimano and some others use mineral oil. most use dot fluid. Lube either with the correct fluid or red rubber grease. work the piston in and out a few times once lubed. Do this with the pads out so as not to contaminate them
Posted : 06/09/2010 7:43 am
