I've got hope tech brakes with M4 callipers running 183mm floating Hope rotors. New rotors are on the shopping list and the question is can I run Shimano ice tech 180mm without any issues or any other 180mm rotor for that matter?
Or what rotors are you running with your M4's
Carlos
Caliper number/which end makes a difference. You could run 205 rotors back in the day front and rear
Jus use a different mount to ensure full pad to disc coverage.
However I have not bothered in the past and my brakes still worked and I didn't die!
Usually you can run any disc with any caliper as long as you use the correct adaptor. I don't know about M4's, however when I fitted E4's on my spitfire with 203 rotors, I had problems with the caliper fouling the mount (I tried Shimano and Superstar mounts) and I had to get the genuine Hope mount to make it fit. The reason I mention this is that Hope don't make a 180 mount and you may have problems with it fouling on another brand.
Personally I'd stick with Hope 183 rotors.
Is it purely a money saving exercise running shimano rotors instead of replacing with hope floating ones? Would look a bit odd in my eyes.
I'm running floating 203s front and back with my m4's. It may have been an over reaction, but I experienced brake fade a few times on a trip to the alps thw first time I went. I didn't want to ever have that feeling again.
Thanks for the replies.
I'll prob end up sticking with Hope tbh. I wasn't too fussed on the look of the Ice Tech ones or cash saving, I just wondered what other options there were other than to run Hope.
