Disc Brakes on Road...
[Closed] Disc Brakes on Roadbikes - Lance Tweets
I've skidded my front wheel in an emergency stop - from 50mph, down to 10ish (corner tighter than I remembered) in a very short amount of time.
Surely whether you go over the bars or skid just depends on if you keep your weight back when you use the front brake. On any well set up bike it will be possible to make the back wheel go up in the air if your weight is forward, and possible to skid the front wheel if you keep your weight back. If bunging on the front brake just chucked you over the bars, there'd be no way to brake sensibly when going downhill or going fast. The front brake = over the bars thing is surely only if you're not very good at braking?
Joe
Posted : 11/08/2009 12:06 pm
Have always liked the idea of small discs on a winter road bike and toyed with putting some (mechanical) ones on my ticross which does winter road hack duties as well as touring and CX. In the end itwas the faff of making them work with a rack that put me off.
For me it would be about rim wear and longevity. On a 3 day tour fully loaded in the rain in the hills I went through a set of pads in a day and was worried about making it back.
On a race bike the other problem might be the slightly longer time to get the wheel on and off, aligining the disc between the pads in the even of puncture. Something the XC mtb boys must have perfected I guess.
Posted : 11/08/2009 12:14 pm
Why do people make categoris statements like this with no datqa whatsoever to back it up?
...and what aracer said re locking front wheels, I'd love to see it.
What data do you want? I have decent rim brakes that if I so chose, can apply too much power - what data do I need to qualify myself to partake in this debate then?
Technically if your front pitches you over the bar, the wheel has locked to do this no? Why do you assume locking = skidding? *sigh*
Posted : 11/08/2009 12:27 pm
 Sam
I think it could happen for high-end road bikes - for touring/commuting/ recreational riding as many have already pointed out it already exists. That's all been elaborated well by those above but I think there could be additional benefits for racing which haven't been touched on.
It's all about wheels. The lightest, fastest wheels these days are tubs on carbon rims. These are fantastic; light, stiff, fast rolling - but they have one (potentially literally) fatal flaw - braking. Carbon rims build up heat and don't dissipate it so quickly as metal rims. This not only imparis braking performance, but also means on a long alpine descent rims can heat to a point that softens tubular glue and it becomes more likely to roll a tyre (see Joseba Beloki in the tour 2003) which gets ugly fast.
Discs would give you the assurance of consistent braking (let alone when wet) without the concern of overheating rims and rolling tyres. Descents could be faster knowing that you can brake late and hard with confidence, not have to back off in order not to overheat brakes.
It certainly could be done with the technology available, whether it actually happens is another question, roadies are a conservative bunch and it'd likely be outlawed by the UCI (if in fact it's not aleady) before it even got off the ground.
Posted : 11/08/2009 12:35 pm
I've locked the front up on my road bike, more becuase it was wet and the blocks snagged on a worn rim than becuase of pure braking effort. I was in the drops, locked, lost balance, got off the brake and just failed to wrench balance back in time, so I hit the deck. Hard.
Never managed to lock the front JRA, even with shimmy dual pivots and anchor like fibrax red pads.
As for people talking about the discs boiling on alpine descents, when racing you don't drag the brakes that much. Even descending big alpine passes in a steady peloton on narrow twisty you only need to take a little energy out to stop you ruinning into the guy in front. If the road off the top is wide, you can pretty much stay off the brakes and only feed them in for big corners, which is exactly what discs are good at.
I can see them coming in if they start to develop road disc specific systems.
I betcha that in a few years time they'll have itsy-bitsy lovely wee disc brakes. It will happen.
Posted : 11/08/2009 12:56 pm
 igm
When I brake hard on the road bike I do find myself easing my bum off the back of the seat to prevent myself going over the bars - and that's with 120psi in the tubes.
It's probably either because I'm a mountain biker or because I'm rubbish
Posted : 11/08/2009 1:19 pm
"disc brakes and QR levers at 50mph? thats going to seriously hurt"
nah... it won't be likely to eject as the contact patch of the tyre isn't going to allow enough force. it's a heat build-up and modulation issue, not power - a road disc would have advantages in reducing rim heat allowing lighter rims etc. also lighter stays could add comfort and light forks are already getting stiff enough to cope.
Shimano have the STI technology already in the Dual Control lever - it could be closer than you think.
Posted : 11/08/2009 1:29 pm
Was Lance advocating the use of discs on road bikes? As L.A has a stake in SRAM I wouldn't be surprised if SRAM are soon to be launching a new road groupset including disc brakes!!
Mr Cynical 🙂
Posted : 11/08/2009 1:31 pm
You have seen a road bike haven't you - lower BB, lower front end, lower position?
All very true, but the bike itself is a tiny proportion of total mass, the rider is generally in a raised position to increase pedalling efficiency, it's true they are bent over to increase aerodynamic profile, but they're COM is still in an elevated position compared to a mountain bike rider etc. etc.
Anyway, as many have pointed out in my absence, clearly poss to lock the wheel with calipers but all depends on conditions, riding position etc. etc.
The numerous benefits of discs have also been stated clearly. I think it'd be a great idea on tour stages with big hairy descents, as has been pointed out, all a question of regulation. If it can be proven they are effective and safer then why not.
Posted : 11/08/2009 1:32 pm
GaryLake - Member
you wrote this, a statement of fact, with nothing to back it up - that's my point.
23c tyres on a racing bike really can't cope with any more braking power than a quality calliper already offers
And
I guess if you need to argue semantics then you've already lost. *sigh*
Posted : 11/08/2009 1:33 pm
My saddle is 2cm higher on my road bike than on my mtb. I'll bet that the combination of lower BB and much flatter back position means that my CoG is lower on my road bike than on my mtb.
Posted : 11/08/2009 1:34 pm
I don't know what to say cynic-al lol
Ignoring that, I can see people's points about rim development and how discs would allow that.
Posted : 11/08/2009 1:44 pm
Maybe so clubber, but when you're sat up on a mountain bike you're also bringing the position of the COM further back, therefore increasing the moment exerted by your weight (action of gravity). It may therefore be harder for you to pitch over the bars comparatively.
This fixation on skidding/pitching is a very complicated story, and a tricky dynamical system.
For example, as you beging to pitch, the moment through gravity decreases and the moment from braking increases. This is because you're moving up and forward. Combine this with the increased contact force on the front tyre and the capacity of the tyre correspondingly increases.
I'm trying to paint a picture of why this may happen and what's going on. I'm not giving a definitive ranking table on pitching probabilities and COM position.
I'm beginning to see why so many needless pompous arguments on here continue ad infinitum.
Can't help feeling the major point is being missed; on a road racing bike, you don't need to brake to the same extent as a mountain bike.
It's racing.
Fast is good.
Stopping on a sixpence is simply not required.
In addition, unless every bike in the peloton is equipped the same way, any disparity in braking ability will cause crashes.
...and the carbon rims overheating on descents thing applies to aluminium rims with tubs too...
Posted : 11/08/2009 2:11 pm
I might as well add my bit. Disks on road bikes would be great, I do d lot of muddy back lane commuting and go through pads and rims pretty fast, would love a fast bike with the ability to run disks.
Too powerful is nonsense, if the lever feel is good and sensibly modulated there is no such thing as too powerful, only idiots who pull the lever too hard. MotoGP brakes are far too powerful, as witnessed a couple of years ago when one of the Ducati boys flipped himself onto his head when the brake lever caught another bike, but the ability to brake with a light pressure applied by a single finger is less fatiguing. Anyone want to go back to having to yank the lever with three fingers on an MTB? Modulation and feel is the key.
If the UCI get their head out of their arse disks will be coming to roadbikes purely on aerodynamic grounds. Can't wait.
Posted : 11/08/2009 2:33 pm
 Aidy
Wouldn't the point of running discs on a road bike be that you could build more exotic wheels due to the lack of need for braking surface?
Swapping rotating weight for non-rotating weight strikes me as a good idea.
Posted : 11/08/2009 3:06 pm
 GW
non rotating discs? Cool!! 😆
mincing off road is one thing, but worrying about brakes on a roadbike? 🙄 what a bunch ay fannies!!
Posted : 11/08/2009 3:46 pm
Given disc brakes would be less aero, how does that work?
Posted : 11/08/2009 9:19 pm
Because people who don't actually understand the issue properly attempt to theorise and argue with those who do? 🙄
The pitching over thing is pretty straightforward. Any normal position on a bike - road or mountain bike position, I'm only excluding things like recumbents or easy riders here (and of course tandems - they do skid the front wheel) - the CofM is high enough that you'll pitch over the bars if you pull the front brake on full on normal tarmac with any decent road tyre. That's assuming a front brake strong enough to lock the front wheel, which any normal road caliper is.
The confusion is all in the initial statement about disc brakes being too powerful for skinny 23mm road tyres. The implication being that they're not too powerful for all the extra grip you get from fat MTB tyres. The problem with that (I'm sure this will provoke lots more disagreement) is that you don't actually get more grip from MTB tyres, you get less! Either off-road because of loose surfaces, or on road because of squirm (though on normal dry tarmac you should have enough grip from any tyre to pitch over). Hence why in some circumstances you can skid the front wheel on a MTB - nothing to do with CofM.
Posted : 11/08/2009 11:08 pm
If (when) they bring road racing disc will they be carbon so that they can be moulded as one with the hub?
Aren't disc currently not allowed in top end cyclo cross? when they allow this i recon that the road can't be far behind.
Posted : 11/08/2009 11:28 pm
~has images of TDF mechanics with scolds up their arms trying to change wheels as quickly as possibly~
UCI should just lower the weight limit. I think it's crazy that the ladies have to have bikes also with the same weight limit... just think how many weights they have to add.
Posted : 11/08/2009 11:54 pm
6.8kg is the set limit so that the bikes can withstand the rigures of racing, going any lighter will compromise strength and the safety of the riders, which is of course paramount. If you've ever picked a bike up weighing 6.8kg, you'll soon realise it's very light. Most of the riders bikes are usually around 7.0kg+ anyway.
Discs brakes aren't used because the injuries resulting from their use would be pretty serious, eg: fingers comming off (160 rider peloton bar to bar, tyre to tyre). The majority of the bikes wouldn't be able to withstand the force either. That and the fact they aren't needed..
Ciao 😉
Posted : 12/08/2009 12:04 am
Does that mean the bikes which had added ballast to make the weight limit weren't safe? Is my UCI illegal bike unsafe?
Maybe the normal day to day bikes - I very much doubt any of the top 10 in the TdF were riding mountain stages with bikes that weighed any more than 6.81kg. I don't suppose Emma Pooley's bike ever weighs more than 6.81kg.
Posted : 12/08/2009 12:22 am
The ballast which are sometimes added, make up the couple of hundred grams that a bike could be under, it's not like they're adding a kilo to a bike that weighs 5.8kg.
As for the weight of the top-10 riders bikes, I'd agree with that they're all going to be use as light a bike as possible. But then that opens up the can of worms of power/weight/watts Vs weight of a bike argument, which some hsay the weight of the bike makes next to no difference, so in theory a top rider could ride a 25lb steel bike, and still be up in the GC...yeah. 😐
Posted : 12/08/2009 1:03 am
this point about injuries is a nonsense.
When has anyone heard of similar injuries being caused by spokes? Never, because riders do not fall into each others wheels. Even if they did, simple fairings could avoid this.
Am also loving the armchair experts who "know" the frames couldn't withstand the forces. You designed them did you? Oh....
Posted : 12/08/2009 6:41 am
What about the dishing of the wheels? Surely adding a disc to already very narrow wheels would result in the spokes being almost vertical making for a very flimsy wheel?
Posted : 12/08/2009 6:54 am
and you know enough about their design/construction to say they are wrong?
Posted : 12/08/2009 7:30 am
cynic-al - Member
I agree with this also there is a chainset spinning round that has a nice sharp toothed edge to it and that isn't seen as a problem and don't tell me that the riders leg protects others from it as that would only be true for part of the rotation.
Posted : 12/08/2009 7:32 am
Best thread in ages. Good work fellas!
Posted : 12/08/2009 7:49 am
 pjd
what if the bike was on a treadmill going at same speed in opposite direction would the bike take off?
Posted : 12/08/2009 7:51 am
chunky_pott - Member
Road front wheels are the same hub width as mtbs. Road rear wheels are 5mm narrower at the hub than mtbs. 5mm at the rear is not enough to make the spokes vertical if a disc was fitted.
Posted : 12/08/2009 8:40 am
thats assuming your going to use the same hub/fork/disc standards as mtb's. If road specific disc systems do get developed you can bet your house they wont be using the current 'IS' dimensions, so wheel dish will not be an issue.
Posted : 12/08/2009 9:07 am
I love the idea that the main thing you'd be worried about in a 150 rider pile up at 40 miles an hour is little disc brakes - I'd be a bit more concenred about the ground!
Posted : 12/08/2009 9:20 am
I wouldn't say you're completely without understanding 😉
Anyway, I think this is the stage when we agree to disagree.
Tara
Posted : 12/08/2009 9:30 am
momentum - Member
Posted : 12/08/2009 9:41 am
Moment of inertia? I would imagine any weight lost from the perifery of the wheel (i.e. being able to make rims with no lateral strength) would reduce moment of inertia of the wheel a noticable amount since inertia is a function of the mass and its radial position squared.
Although overall weight would be the same or maybe even greater, the advantage in acceleration would be well worth it for sprinters/ climbers i suspect.
Posted : 12/08/2009 9:48 am
So from my perspective as an armchair expert, I can conclude that all road frames are now strong enough to withstand disk brake use, hence why so many manufacturers are now producing road bikes with disc brakes.
Oh wait.
Posted : 12/08/2009 11:26 am
Have you seen this: http://www.canyon.com/_en/technology/project68.html
I think then main issue is that having disc brakes on Pro Tour level roadbike would require major changes in wheels, forks and frames. Not likely to happen anytime soon with UCI being very eh traditional about equipment.
btw, I have seen report about one local road race where one rider lost a finger in a big crash, can't remember which components caused the damage.
Posted : 12/08/2009 11:35 am
0091paddy - Member
Oh wait.
It'a quite simple. You say "road frames cannot take the forces of disc brakes".
I say "You don't know that do you?". I do [b]not[/b] say "yes they can". Please don't mis-represent me.
As rehearsed many thimes there are ample reasons as to why no one makes high end road bikes with discs, and if you can read the thread you'll find them here...oh hang on!
Posted : 12/08/2009 11:54 am
Given I've not done a stress analysis of individual frames, no. Given disc brakes do require extra strength in the frame and forks, that extra strength means extra weight, and that low weight is one of the driving criteria behind high end frame design, then my considered opinion would be that it's so unlikely they are strong enough it's not even an interesting point of discusssion.
Posted : 12/08/2009 12:06 pm
But disc brakes only need stronger frames if you want to slow down faster, which you don't as we've already agreed that normal calipers are powerful enough for the required rates of retardation. There's an apt word for this thread!
So you'd be designing discs with smaller rotors that would exert the same force, or bigger rotors that require less force on the bars. Where does this idea that riders pull on the brakes as hard as they can and are only saved from certain death by the poor performance of their brakes come from?
Posted : 12/08/2009 12:13 pm
I've read everything on this thread!
I can only know what I know from what I've seen,heard and read, if a disc brakes advantages could outway the redevelopment and redesign costs of a bike, then why aren't they all over bikes that aren't intended for competition use? Audax bikes/touring bikes/sportive bikes/ etc. I know that some touring bikes have them, and the advantage there is greater modulation and power given the extra kilos carried, but that isn't the question here.
Creating a solution for a problem that doesn't exist springs to mind in this instance.
*rolls eyes*
So if your top end road frame and fork package that your pro team are riding is 1kg under the weight limit, making you stick lumps of lead to it to make it UCI 'legal', adding 500g more carbon here and there to be able to run some newly developed road specific disks, further dropping rotational weight and massivly increasing brake performance, as well as gaining a reputation as an innovator and reams of media coverage is neither feasible, nor an interesting point of discussion?
Posted : 12/08/2009 12:23 pm
I dont understand where this 'road frames are too light' idea comes from? and all this 'your a frame designer are you?' puffing of chests.
You simply need to look at what is out there now to see its entirely possible...
Plenty of race MTB frames can be had down at around 1kg, same sort of weight as most road frames. Road forks are around 300-400g for good ones, where as ritchey make a carbon Disc MTB fork for under 500g. Not exactly a leap up in weight (infact i reckon most stock road bike frame/fork combos weigh more than 1800g)
Posted : 12/08/2009 12:26 pm
Page 2 / 3
