Disc brake hose fra...
[Closed] Disc brake hose frame guides/clips? Or mounts for V brake studs?
 maxb
Anyone got any links for this sort of thing? Fitting a disc brake tab to a non disc (V brake) frame and considering options for running the hose neatly to avoid welded on guides. Not sure if there were any adaptors to utilise the V brake stud hole for a guide?
Posted : 24/09/2016 2:22 pm
I've seen some bit can't remember where. Fairly sure you can bond guides these days, not the plastic and ziptie ones but proper metal ones
Posted : 24/09/2016 2:31 pm
Hope used to do [url= http://www.cheapbikeparts360.com/products/hope-hose-guideplug-kit/ ]These Hose guide plug[/url] that screwed into the rear brake bosses, i had them on my Genesis SS and they worked fine, dunno if you can still get them though - give hope a call as they prob still have a box of them lying around.
Or you could [url= http://www.cyclebasket.com/m9b0s313p258/M-PART_Fork_Hydraulic_Hose_Guide_-_8mm ]try these cheap n' cheerful but unsightly M-part hose clips[/url]
Posted : 24/09/2016 4:49 pm
 maxb
Great - thanks Soma.
If anyone has one of the Hope ones or similar please let me know. ๐Ÿ™‚
Posted : 25/09/2016 12:06 pm
http://singletrackworld.com/forum/topic/framw-hose-guide-modification
Another version, costs pence
Posted : 25/09/2016 12:10 pm
