Years ago I seem to remember someone modified a loop style closed guide to allow easy hose removal without disconnecting.
I think it was on an Inbred but it may hae been something else, anyone remember what was done or how would be a good way to do it?
I've got zip ties holding the hose currently but would like to neaten it up a bit.
Fine for forks not so good on the frame though.
Should have said I'l not too bothered about ruining the paint as it's goig to be refinished.
Ive used these on my Airborne frame
http://www.swinnertoncycles.co.uk/M-Part-Part-M-Part-Disc-Cable-Guide-Set.aspx
It works anywhere you'd use a cable tie.
I like that cable tie trick. Will have a go at that on my forks.
Not saying it wouldn't work just when you are holding the hose away from the forks it looks quite neat but when you have empty hose guides with that sticking out it wouldn't look so neat.
May just play with the dremmel to see what I can do as one will be spare with a singe ring up front.
I also remember seeing someone drill the guides or split them or something a while ago so they were more like the clip or zip tie ones can't remember how they did it though.
you could carefully drill through the base of the guide so you can pass a cable tie through from one side to the other, then trim the top off to open it just enough so you can push a cable outer in. Then just the cable tie to secure it. Should be okay on steel but wouldn't on aluminium.
Bump for the weekday lot.
Wish I could edit the title!
Simon, any close up pictures, and directions of what exactly you did?
As I think that's a lot neater than what I have currently.
I've had that frame properly refurbished since then so I can't get better photos. I used a hacksaw to cut through the loops in the middle and opened up them up a little with some pliers to turn them into open horseshoe shapes which cup the hose nicely. I may have actually removed a bit of metal too, I can't remember, but I certainly filed them down to make them neater. Then I drilled the small holes for the cable ties.
Cheers, I'll have an attack with the dremel and see what I can do.
